Maintenance Required?
Old Nov 3, 2005 | 10:47 AM
Ontilt's Avatar
Pimpin Ain't Easy
How do you turn ours off, when it hits the 10,000 mile mark and on?
Old Nov 3, 2005 | 10:54 AM
LoveMyTL-S's Avatar
It's in the manual
Old Nov 3, 2005 | 11:04 AM
jlukja's Avatar
Search is your friend.
http://www.acura-tsx.com/forums/show...ntenance+light
Old Nov 3, 2005 | 08:50 PM
loxllxol's Avatar
damn, i did EXACTLY what the manual told me:
1. Press reset and hold reset
2. Turn key to ON (II)
3. Wait 10 sec until the light resets.
Did this several times, but it never reset! Anyone have that same pb?
Old Nov 7, 2005 | 08:33 PM
Stevestr's Avatar
Looking at the '15 TLX
I believe you have to press and HOLD reset. Not press, release, and hold.
Otherwise you appear to be doing it correctly.
Old Nov 9, 2005 | 02:09 PM
playdoh's Avatar
Lies!
Ok, I have an '05 TSX, and like everyone else my MAINT REQ'D light came on around 8000 miles. I have tried holding down the trip reset button, turning the ignition on (i tried both to just acc power and starting the car) and waiting about 10 seconds.
No dice. Still flashes when I start the car. Am I doing something wrong? Has anyone successfully reset this warning light?
Thanks!
Old Nov 9, 2005 | 02:31 PM
moda_way's Avatar
Be sure you hitting ON II. if you start the car, it won't work either. I've used this method and it works fine for me...
Old Nov 10, 2005 | 10:14 AM
atang79's Avatar
Single Sailor
Thanks!
Be sure you're holding the reset button before you turn your key to II.
Old Nov 12, 2005 | 12:19 AM
playdoh's Avatar
I got it to work thanks! I wound up holding it down for like 30 seconds.
Old Nov 12, 2005 | 12:46 PM
ILoveMyHonda's Avatar
17781708
worked for me.....hold down b4 inserting key and just turn to accOn position. don't start the car or it wont work.
Old Dec 7, 2005 | 08:50 AM
SilverSting's Avatar
I press and hold the reset button, turn the key to on (pos II)... and after ten seconds the temperature gauge starts adjusting itself and the reset light stays on!
Old Dec 8, 2005 | 06:31 AM
playdoh's Avatar
Hold the botton down, then turn the key to on and wait approx 30 seconds to be sure. My temp started adjusting also (I had to readjust the temp when I was done, apparently you can set it to display up to +5 or -5 degrees from the reading). The "key" is to hold the button down for a good 30 seconds. That worked for me.
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
joflewbyu2
Aug 18, 2019 10:38 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
