low engine oil
Old Dec 12, 2004 | 02:10 PM
TSXDude's Avatar
Noobie 6MT driver
low engine oil
I'm at 6000 km, and i checked my engine oil this morning, and it is right below the lower dot
I ran it for a less than a min or so before checking. Could that affect it somehow?? i will check it again later tonite....
Old Dec 12, 2004 | 07:32 PM
Viking's Avatar
Quattro in.....
This was previously discussed in the thread link below:
https://acurazine.com/forums/showthread.php?t=15665
Old Dec 13, 2004 | 06:27 AM
sauceman's Avatar
Moderator Alumnus
No, not with only a quart missing. But to be sure, just add in another quart of 5W30.
Old Dec 13, 2004 | 07:08 AM
biker's Avatar
I'm sure it has been low for quite some time. Just add a qt - you'll be fine.
Old Dec 13, 2004 | 08:29 AM
TSXDude's Avatar
Noobie 6MT driver
checked it again this morning before going to work, the oil is a tiny bit over the lower dot. I guess i'll add half a quart back just to be sure.
Thanks for the response
Old Dec 13, 2004 | 08:55 AM
biker's Avatar
Just noticed that you checked it AFTER you started the engine always check the oil level with the engine cold.
Old Dec 13, 2004 | 01:32 PM
TSXDude's Avatar
Noobie 6MT driver
yea, that make sense, because all the oil will be in the drain pan, rite?
but i believe the manual says to check the oil at the fill-up station.. meaning the engine will be warm. How does that make an accurate reading?
Old Dec 13, 2004 | 01:37 PM
biker's Avatar
If you let it sit for a while the oil will drain back into the pan but not like the first thing in the morning. You just found out the diff between a reading before and after starting the engine.
mada51589
Jan 9, 2025 04:40 PM
pizokk1
Sep 17, 2015 09:29 AM
datadr
Sep 12, 2015 09:12 PM
HeloDown
Sep 8, 2015 06:51 PM
Desert Ridge
Sep 5, 2015 09:47 AM
