Loud Engine Noise?
Old May 1, 2010 | 09:38 PM
cman219's Avatar
Loud Engine Noise?
Hi all, i'm about the purchase a used manual 2004 Acura TSX with 74,000 miles on it. I brought it to my mechanic and he said the car is good but the only thing he noted was that the engine sounded louder than normal, and i noticed this too. Could this be because the owner only changed the oil with synthetic oil every 7000 miles? (He's owned the car for 2 years and only drove 15,000 miles). It sounds a little like an older 4 cylinder economy car. But its not THAT bad, just curious.
Old May 2, 2010 | 01:46 AM
Itchytoe's Avatar
Modding newbie
You'd have to be more specific about the noise. Was the resonator removed? That can change the way it sounds. Is there a hole in the muffler? There could be lots of reasons it "sounds loud".
Old May 2, 2010 | 07:05 PM
cman219's Avatar
Well i'm not too familiar with sound diagnosis for cars yet, so i really can't say much more than it sounds almost like what an old 4 cylinder economy car would sound like. Sort of like a lower than normal frequency "puff puff puff" sound. It doesn't sound as smooth as a new car, the "puff's" are distinguishable.
Old May 2, 2010 | 07:06 PM
cman219's Avatar
Oh and i don't think the resonator was removed or there was a leak in the exhaust system. My mechanic couldn't determine the reason either. All he said was that there isn't anything to worry about.
Old May 2, 2010 | 07:07 PM
cman219's Avatar
Maybe its a mild case of piston slap because of the relatively high mileage (74k)?
Old May 2, 2010 | 09:18 PM
huludicidal's Avatar
Almost Doctor
74k miles is considered a low mileage '04. As far as the oil, it is a 10k service item so 7k synthetic oil changes is a better than preferred maintenance schedule.
Old May 3, 2010 | 11:53 AM
cman219's Avatar
Ohh i see. Well i guess i'll have to see when/if i get the car. My mechanic and friend who used to be a mechanic both said the car is fine. Friend told me to use seafoam to clear out some of the gunk.
Old May 5, 2010 | 07:48 AM
oldguytsxer's Avatar
compression check
did your mechanic check thoroughly?
Old May 5, 2010 | 07:52 AM
nj2pa2nc's Avatar
it's a car-drive it
that is not high mileage-my 06 has almost 104K problem free miles now.
Old May 5, 2010 | 10:44 AM
thunder04's Avatar
Sweet!
^ My '04 has almost 130k miles on it (129k and change) and the only problem I had was with the A/C system. Engine wise, it's a solid vehicle. It still runs great.
Feb 25, 2020 09:57 AM
Sep 15, 2015 06:44 PM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
