Locked in Park!
Locked in Park!
Hi Guys,
So here's what happened -- I reversed into my parking spot this morning at work. I put it in to park and open the door to check if the guy beside me parked in crooked or was it me (it was the guy beside me) meanwhile the car is still running. I decide to move it back it bit more but when I go to shift the car from park to reverse it won't move. It moves only the amount that it would typically move when the brake is not pressed.
I've tried a few things
- turn off the car, turn it back on
- make sure that i've got the brake pressed in
- move the steering wheel around
I'm out of ideas -- any thoughts??
Thanks!
Thanks!
Looking at the '15 TLX
Check your owner's manual. There's a procedure for manually overriding the Park interlock that involves removing a cover near the shifter and inserting a screwdriver. That will temporarily get you out of park but you'll have to keep doing this until you get the car looked at.
Thanks Stevestr!
That saved me the cost of towing..
I think it may be linked to a switch or fuse. I noticed that the VSA light was off and also the brake lights weren't functioning. It's at the dealership right now, see what they say. Any idea how much a fuse will cost?
Oliver!!!
Probably not a fuse, probably the switch on the brake petal that tells the car when its being pressed. That would cause the park interlock to not function as well as the brake lights.
I too have dis problem..my 00 tl will not shift into gear....i bought some new braking lights bulbs which i thought were tha problem and is not...so far researching on dis topics it seems like tha problem is tha braking switch....someone please me know if you guys have a solution to dis problem cuz last thing i wanna do is take it to tha dealership
found tha diy haha just gotta look around eh,,,https://acurazine.com/forums/2g-tl-1999-2003-98/diy-brake-switch-614710/
It was the brake switch -- the part is about $10 and its fairly easy to replace. I had the dealer replace it after convincing them that it was infact the brake switch and it's a 5 minute job.
MrHeeltoe
20
02-23-2023 01:54 PM
soupi
14
11-15-2015 11:15 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
