locked out of nav system/screen!
Old Jan 7, 2006 | 08:53 PM
myoclonic's Avatar
5th Gear
Please let me know if anyone has experienced this or can help ...
I have a new 2006 with nav. Today I made the drive up the I5 from LA to SF, where I live during the school year, and I set the nav to go "home" (my SF address). Everything was fine until I stopped for gas, and when I started up the car again, the nav displayed a PIN entry screen instead of the map that I expected. I had never entered a PIN for my personal information or otherwise, and nothing I tried could unlock the system. I even attempted to enter the radio unlock code and that didn't work either.
The screen is now stuck on the PIN entry mode, and I can't use it to display audio or AC information.
Does anyone have any idea what's going on? Is this a software bug?
Old Jan 7, 2006 | 09:43 PM
moda_way's Avatar
I would call Acura service first of all. They can tell you what is going on.
No idea otherwise.
Old Jan 7, 2006 | 09:46 PM
KunalPatel87's Avatar
TEMPLE OWLS Don't Sleep
No idea otherwise.
No other way out of this...
Old Jan 7, 2006 | 10:01 PM
Acura_Lexus's Avatar
No need to panic, I went throught the same thing last week. Inside your glovebox you will find a card with a PIN #. this card is what was used when the car was programmed when off the boat...Type in that PIN and you should be ok...
hope this helps
Old Jan 7, 2006 | 10:03 PM
gt0279a's Avatar
You may be able to disconnet the battery for atleast 30 seconds and try it from there.
Old Jan 7, 2006 | 11:10 PM
TacoBellSauce's Avatar
disconnecting the battery will cause the PIN screen to display
the car should have come with a card with the navi code on it
if you dont have it, the code is written in the trunk somewhere
all u have to do is enter it and ur set
Old Jan 8, 2006 | 01:28 PM
moda_way's Avatar
hope this helps
There is also a sticker in the glove box, I believe above and inside. I took mine off a long time ago.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
