Lisence plate...two bottom screws missing?!
Old Dec 10, 2003 | 06:04 PM
Amcel330's Avatar
Hi I just got plates on my new TSX and there are no holes for the two bottom screws for the rear plate to go. Am I mistaken or does anybody else have this problem? Thanks--
Old Dec 10, 2003 | 06:28 PM
MikeMa's Avatar
No Longer a Poseur
Re: Lisence plate...two bottom screws missing?!
There is no second set of holes. You just bolt on the top two. Lots of cars these days are like this.
Here is a discussion about what to do about the vibrations the plate gives off when you shut the trunk.
Old Dec 10, 2003 | 10:11 PM
e_lectro's Avatar
Still here
yeah, its not a problem, its the design. My plate rattled like crazy after I put my sub in, but some dynamat took care of that.
Old Dec 11, 2003 | 01:39 PM
jiggaman's Avatar
I spend 2 much time here
i just took mine off and put duct tape behind it do reduce the sound. so far so good. also i now use the injen license plate holder that came with my intake.
Old Dec 12, 2003 | 09:38 AM
gcolby03's Avatar
TSX Owner
I called Acura Client Services directly about this issue because mine didn't come with pads either and my salesperson had never heard of them. The gentleman at Acura Client Services promptly looked the matter up in his parts listing and said that yes the TSX's do come with two pads called "License Plate Protectors" and they should be included with the new car. He advised me to check back with the dealer to get them.
Old Dec 17, 2003 | 11:48 PM
tzx's Avatar
tzx
Checked with my service dept. and was told that there are no "Licence Plate Protectors".
I was told to try some tape in the back of the plate. What happened to the 2 little plastic tabs, that my old Accord had, that you could slip the plate into for support? Talk about skimping/cutting corners by the manufacturer to save a few cents!
Old Dec 18, 2003 | 08:26 AM
ImportsRhot's Avatar
I had the same rattling problem when i close my trunk, but i took it to the dealer and they fixed it for me by putting a foam piece that came with the car on the back of the license plate. Now it's fixed.
Old Dec 18, 2003 | 05:03 PM
ostrich's Avatar
The Acura customer service person told me that there was actually an Advisory on this issue, though I am not sure what the fix was...
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Desert Ridge
Sep 27, 2015 02:37 PM
