LED problem
Old Apr 23, 2007 | 11:21 PM
TacoBellSauce's Avatar
LED problem
hey everyone
i installed LED bulbs like 2 months ago in my TSX and they were working fine until yesterday when the pass side map and the rear dome light went out
does anyone know if its the bulbs or fuse?
also, i bought them from superbrightleds, is there any warranty on the bulbs?
the bulbs are the 9LED ones
thanks a lot
Old Apr 23, 2007 | 11:46 PM
dj Dozhe's Avatar
6MT or Death
I'd suggest tossing in the oem lights you swapped out, or if you threw them out go down to autozone and get a replacement. If those lights work then it'd point to faulty LEDs. If not then it's time to try replacing the fuse or inspect the housing.
no clue on the warranty issue. good luck.
Old Apr 24, 2007 | 06:55 AM
LoveMyTL-S's Avatar
The first thing I'd do is check the fuse. Easy and quick fix if it's blown. It wierd they would both go at the same time.
Old Apr 24, 2007 | 07:23 AM
moda_way's Avatar
Originally Posted by TacoBellSauce
hey everyone
thanks a lot
Follow dj Dozhe's advice.
As for warranty, if you still have the receipt, I believe they warranty their products for 1 yr with proof of purchase. They did last time I checked.
Old Apr 24, 2007 | 11:19 PM
Ishakir's Avatar
Hello,
Three out of four of my LEDs just went out today which I had bought from superbrightleds about 3 months ago. I've previously already replaced one in the rear dome, and I now have to replace both + 1 front map light. I currently only have 1 working front map light in the entire cabin. Is this a normal thing for LEDs? I'm figuring that there's too much current being applied to these things and it just quickly burns them out. I'm gonna order another set and give them another shot, if not I'm just gonna switch back to the normal boring bulbs
Old Apr 25, 2007 | 05:12 AM
moda_way's Avatar
Originally Posted by Ishakir
Hello,
I haven't had any LEDs on the festoons go out, but I have had color inconsistency. Again, if you have the receipts from superbrights.com, I believe they warranty them for 1 year.
Old Apr 25, 2007 | 09:35 AM
1slicktL's Avatar
i got my led from tec toyz and they haven't gone dead on me yet only probelm is on the off position it still stay lite a little any way to fix that
Old Apr 25, 2007 | 10:01 AM
TodaSi's Avatar
Hmmm, I was going to get LED's but maybe I should think on it a while
Old Apr 25, 2007 | 07:17 PM
dj Dozhe's Avatar
6MT or Death
I also got mine from tec toyz and have had no problems. I leave my setting on "door" instead of "off" and never have an issue with it. It is a commonly stated issue that when set to "off" it lets off a small amount of light.
Please understand this means that if set to "door" they will turn on when the doors open, and then completely turn off when the doors are shut. When set to "off" they never turn on completely, but instead stay on at a low level.
That being said, I love my LEDs (blue 9LED setup), and I've gotten compliments from both my friends and my parents.
Old May 5, 2007 | 07:10 PM
the thing with mine i just noticted is that the rear ones work only when they want to
itll be on one min then off the other
but the one in the front pass map light does not turn on at all
pplcrew
Jan 30, 2021 08:59 AM
jblessing
Aug 8, 2018 09:43 PM
usual.acura
3G MDX (2014-2020)
14
Sep 19, 2015 05:01 PM
Sep 17, 2015 09:01 PM
Greengecko
Sep 16, 2015 08:19 PM
