Issue starting car
Old Jan 27, 2019 | 12:38 AM
uncommon's Avatar
3rd Gear
Issue starting car
TSX 2005 having intermittent starting issues. When I crank the starter I have had to crank it up to 4 times to get the engine running. It seem random. I once started the car without issue and turned it off then back on in two minutes and I would have crank it many times. The worst part is when I take it to the shop they tell me it could not reproduce the issue. I had the battery and alternator checked out and they are good. I my thought is it could be the fuel pump? I dont want to start replacing things at random.
Old Jan 27, 2019 | 01:35 AM
C25A1guy's Avatar
I can divide by zero
Possibly the reef valve in the pump (non-serviceable) not maintaining the pressure in the line after shut off or leak after the pump somewhere. Best way to diagnose is to attach a fuel pressure gauge, start car and allow to run for a few minutes. Shut off and observe the fuel pressure for pressure loss. if no leaks found, replace pump.
Old Jan 27, 2019 | 05:17 PM
uncommon's Avatar
3rd Gear
Do you know what the pressure should be?
Old Jan 29, 2019 | 09:51 AM
TexasHonda's Avatar
Checking fuel pressure requires an expensive test kit to fit a test gauge to the system. Most shops will have the equipment.
An indirect pressure test can be performed by turning keyswitch to on, pause 3 secs, and then Off. Repeat twice and try starting. If starting is good, then intermittent hard start is fault of leaking check valve in fuel pump. Fix is a new fuel pump.
good luck
hules81
Feb 8, 2014 09:15 AM
mimojadi
Sep 30, 2010 09:25 PM
bimmer88
Technology
48
Apr 21, 2006 10:41 PM
Orlando3.0
Sep 23, 2005 11:57 PM
RaptorCLS
May 15, 2003 07:51 PM
