ingalls etd install question
Old Mar 22, 2008 | 03:18 PM
nycxtsx05's Avatar
i just wanna make sure i got it right when you install the etd starting from the top of the bolt what goes next? right now i have the bolt going thru small washer, rubber o ring, etd , big washer(or bushing or spacer), etd bracket den the nut. is this the right way ?? im pretty sure i got the big washer in the right place but Im not too sure about the small washer and rubber o ring. i have the instructions but i cant really tell in the picture and when you read the instructions it says have the o ring in between the small washer and the etd which should mount on the bracket i dunno im so confused lolz
also I noticed that the bolts are not the same length ones longer does it matter what bolt goes on which bracket ? i put the longer one on the bracket closest to the front of the car but i dont think thats right. also I found another bolt the same size as the smaller one should i just use the two smaller ones ??
Old Mar 22, 2008 | 07:04 PM
nycxtsx05's Avatar
sorry it wont let me edit it but nevermind I believe i found the right picture on the etd should be available to everyone now thread and also i reread the directions and it made a bit more sense it wont let me delete the thread sorry
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
