hope to get the answer
Old Apr 13, 2009 | 08:53 PM
yaze21's Avatar
D.L.T
well to make this quick. i want to buy a Impact Wrench and a very cheap one but some of them have different ft-lbs of torque. how many ft-lbs of torque would the wrench need to take the wheels off the tsx and what lug nut size? thanks in advance
Old Apr 13, 2009 | 10:58 PM
Itchytoe's Avatar
Modding newbie
To do it properly, you shouldn't ever need an impact. 80 ft/lbs of torque is easy to break and that's where your nuts should be set if you put them on correctly last time. If you went to Walmart and let those idiots put your wheels on, they're way too tight and you'll have to work harder to get them off.
To answer your question directly, you'll need 81 ft/lbs of torque to get off properly tightened nuts, which I'd bet any impact can handle since I can do more than that with one hand. Lug nut size? Umm, I'm not sure.
baelim
May 10, 2018 09:53 AM
kev87a
Oct 18, 2015 02:03 AM
c1souk
Sep 28, 2015 11:20 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
