Help! Both Reverse Lighs Went Out
Old Apr 13, 2009 | 12:54 AM
jd33's Avatar
Both my reverse lights are out and it doesn't appear to be the fuse. Bulbs both look fine as well. Any help would be much appreciated ... don't want to have to bring it in for this.
THX
2005 TSX no-navi
Old Apr 13, 2009 | 08:22 AM
troopa1's Avatar
check the fuse properly it could be loose or blown. if you have no dash/map lights its the fuse. this happened to me before
Old Apr 13, 2009 | 08:26 AM
moda_way's Avatar
Has the electrical Recall been done on the car? I believe it directly effects this area.
Old Apr 13, 2009 | 11:52 AM
jd33's Avatar
I'll check into this thanks.
Old Apr 13, 2009 | 12:09 PM
jd33's Avatar
Acura says the recall is only for headlights. I'll double check the fuse, but I already switched it with a new one and they still didn't work.
I'll check the dash/map light. Anyone know the fuse number? ... maybe I'm looking at the wrong fuse.
Old Apr 13, 2009 | 02:02 PM
jd33's Avatar
Dash lights are on, map light is fine. Fuse looks good. I'm thinking I'm gonna have to bring it in.
Another important piece of info: I was messing around with my sub/amp rear 6x9's recently ...
Old Apr 14, 2009 | 12:34 AM
Stevestr's Avatar
Looking at the '15 TLX
1st Gen TSX's (at least '04) had a trunk wire recall where the wire was not protected and could be rubbed breaking the insulation feeding the rear lamps. You may want to check for that recall. Then again, since you were messing with the amps - well I'd just keep that to myself when talking to the dealer.
baelim
May 10, 2018 09:53 AM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
STC
Sep 23, 2015 04:36 PM
