hit a curb; need advice
When trying to avoid a collision with another car in a parking lot, my TSX hit a (relatively high) curb. From the right side, it looks like the picture attached.
The paint is scrached <B>badly</B> underneath. Fortunately, both the rightside doors and the rims of the wheels were not affected.
Now I'd like to replace it rather than repaint it since this car has only 2,000 miles on it. The first question is: is this possible? The second question is: will Acura dealers do it without outsourcing to ourside bodyshops? Overall, I'd appreciate any advice. Thanks very much!
[B]
![](http://enterprise.tbcommerce.com/~wcn/curbed1.jpg)
Re: hit a curb; need advice
Originally posted by algorithm
[B]When trying to avoid a collision with another car in a parking lot, my TSX hit a (relatively high) curb. From the right side, it looks like the picture attached.
i hit a curb just like you and for the same reason. my car was in the shop a month.
better look at your roof around the sunroof opening. my whole roof had to be replaced because the car flexed slightly and caused the roof to wrinkle around the opening in 3 corners.
i bent the lower control arm and damaged the lower subframe. also wasted 3 wheels
it doesnt sound like your car is that bad off by comparason. but they can get the parts if that is what your asking. $10,000 later my car is as good as the day i bought it. and i also had 2,000 miles on the clock when my accident happend.
good luck to you.
such a dirty birdy
These stories of wrinkled roofs and $10K worth of damage from hitting a curb make me worry that the TSX is turning out to be a car that gets excessive damage easily and is expensive to repair. Not good for insurance rates and ownership costs over the long term. Erk.
Re: Re: hit a curb; need advice
Originally posted by Bass Mechanic
eekk! unfortunatly my car was involved in an accident recently i didnt post here i felt too bad abou tit after it happend.
good luck to you.
good luck to you.
and the 10 worth of damage was mainly due to the fact 3 tires and rims for the TSX cost 2100 bucks and the lower subframe peice although not a large peice was over 700 bucks, the roof panel was 450 plus labor and paint and several other smaller less expensive peices adds up quick.
and for the record all the people who complain about rattles must be nuts because after all of this my car is still rattle free.
I had a curb accident too but haven't noticed any wrinkling on my roof when I checked...
algorithm, that part is plastic so it's not going to reshape very well. Your best bet is to find a service shop that can order that part from Honda/Acura and paint it to match your car. At least you avoided an accident with another car =)
Originally posted by bob shiftright
Scary. I had thought that once the roof is buckled in an accident the car is usually totaled. I guess not. Also, on the EURONCAP crash test the car only got 4 (out of 5) stars. The US Accord received 5 stars on the US DOT test and was actually the "top rated" 4-door on the Insurance Institute crash test. Apples and oranges, perhaps, but I'm interested in seeing a US crash test of the car.
also they have a frame alignment machine where they can measure the chassis and pull or (bend) it back into alignment. they can get as accurate as about 1/10th of a mm.
when we say wrinkled i mean that the roof has waves in it , not creases, you would be suprised how much flex there is in a body.
![](http://www.euroncap.com/images/results/large_family_cars/car_169_2003/honda_accord_2003.jpg)
http://www.euroncap.com/details.php3?id=car_169_2003
Interesting. Are the side airbags deploying in a frontal crash test?
I wonder if that body part comes pre-painted; it's probably asking too much.
i want to ride my bicycle
So that means I find a good body shop myself instead of going to the dealership?
I was wrong!
(shocking, I know)....
Anyway, I did a little research and you can get that piece factory painted.
Check out...
http://www.acuraparts247.com/sunnysi...All&vinsrch=no
if that doesn't work, go to http://www.acuraparts247.com/sunnysi...atdisplay.jsp, and go through to select the TSX. Once you're at the page that lists all the parts, check out "Side Sill Garnish" (yes, Garnish), and it list that piece in various colors, list is around $190, they're selling for $150.
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
Check out...
Originally posted by esr5096
Check out...
Check out...
Thanks a lot!
but once this happens... repairing it is a bitch and very costly.
Originally posted by DEVO
in order to wrinkle the roof you have to hit the curb pretty hard and if the curb is high enough and you are going fast enough... this is what is going to happen regardless of car... actually the more a car wrinkles around the cage the better it is from a safety point of view.
Actually the exact same thing happened to me. All you need to do is take it back to the dealer than they will screw it back in for you. Just pay for labour, that's all.....no worries....
esr5096, that is an awesome link. Thanks for hooking us up. This should be accessible somewhere from the main page so readers can get an idea of how much repairs are going to cost, and also if they're getting a fair price on the parts. Man, why pay $500 for fixing a bumper when you can buy a new painted one for $300? Just might do that one of these days, freshen up a car.
Okay, I know one of you has more time than you know what to do with on your hands. I challenge you to take that list of parts and figure out how much it'd cost to build a TSX part by part! Hahaha
Yui, I don't think they sell painted bumpers, did you see the actually bumper on that page pre-painted? Unless they list the part once for each color, it's not pre-painted.
Oh, doh. Hmm... I could still find some place to paint it though, probably higher quality paint job than OEM as well... and still not as expensive as having the dealership do it... it's just the front bumper I'd like to replace - some rock gouged about a centimeter long gash into the front bumper, and plus the dealership had drilled the center hole for the front license plate, bah... maybe I could find some shop to sand it, fill it, and repaint it for cheap instead, hmm....
calrow
05-03-2017 10:21 PM
soupi
14
11-15-2015 11:15 AM
lanechanger
10-13-2015 10:56 AM
4drviper
09-23-2015 09:00 PM
