Hidden rust
Old Jul 12, 2009 | 05:40 PM
Daffunda's Avatar
Hidden rust
Go open your hood. Remove the top black plastic shielding that goes between the grille and the radiator. It is secured by some plastic push pin things.
Once you remove that, you should see several weld spots across metal member that those plastic clips shap into. (Called radiator supports? maybe)
Notice any rust? Mine had minor surface rust on the edges of the metal, right next to the radiator.
Sanded it down and painted it with gobs of touch up paint. Probably a problem where road salt is used.
Old Apr 5, 2010 | 07:32 PM
KartGuy's Avatar
2.3CL
Hey man, do you have a photo??
ITSJESTER
17
Dec 6, 2018 02:29 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
lanechanger
Oct 13, 2015 10:56 AM
polish_pat
Sep 30, 2015 12:22 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
