Hidden rust
Old 07-12-2009, 05:40 PM
Daffunda's Avatar
Hidden rust
Go open your hood. Remove the top black plastic shielding that goes between the grille and the radiator. It is secured by some plastic push pin things.
Once you remove that, you should see several weld spots across metal member that those plastic clips shap into. (Called radiator supports? maybe)
Notice any rust? Mine had minor surface rust on the edges of the metal, right next to the radiator.
Sanded it down and painted it with gobs of touch up paint. Probably a problem where road salt is used.
Old 04-05-2010, 07:32 PM
2.3CL
KartGuy's Avatar
Hey man, do you have a photo??
ITSJESTER
17
12-06-2018 02:29 AM
CL-S progression 01
01-26-2016 04:15 PM
lanechanger
10-13-2015 10:56 AM
polish_pat
09-30-2015 12:22 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
Quick Reply: Hidden rust
