HID replacement Question!!!
Old Apr 16, 2013 | 01:47 PM
kingbigs11's Avatar
7th Gear
I have a 2004 TSX and one of my ballast went bad. Can I replace the stock system for an aftermarket HID kit? Will it plug and play just as a regular car without stock HID would?
Old Apr 16, 2013 | 07:10 PM
mrj's Avatar
mrj
9th Gear
Aftermarket HIDs will not be a direct plug and play. It will be difficult to seal the headlight properly if you're using a aftermarket HID ballast since the OEM ballast is mounted right underneath the headlight. Stick with OEM ballasts.
Old May 5, 2013 | 10:44 PM
Manae's Avatar
This is probably your best bet. Could you replace with aftermarket? Sure...but I think staying OEM would be your best bet. I have aftermarkets in my fogs, but will stay OEM in the headlights. Less hassle that way imo.
oo7spy
Jun 19, 2023 12:48 AM
tman570
Jun 11, 2019 07:56 AM
wusty23jd
Sep 24, 2015 11:41 AM
pozebly
Sep 23, 2015 07:30 AM
voigt
Sep 2, 2015 10:44 PM
