Help! Electrical problem (My Fault)
A little background info first:
I had bought the "Up Window" module in the first group buy. Was excited to get it. Installed it and it didn't work. I went out and bought a multimeter to check the voltages. Yesterday it wasn't so hot outside so decided to trouble shoot my original install. I checked the first wire and nothing. I'm no electrical guy and decided at this point to stop. So I put everything back together.
Later I was going to go grocery shopping, turned the key and went to use my wipers, because it had rained. Nothing! Oh shit! What did I do?? I must of shorted something. I tested some other things and have noticed that now my windows, review mirror, rear window defroster, moon roof and instrument panel don't work. My first thought was to check the fuses. I did and they all look fine, under the hood and inside the cabin. This bites!! Is there some relay module that perhaps I shorted out?
I'm thinking of taking it into the dealership today. Any advise? Other than never ever ever do any electrical work on my car............
Originally Posted by cybereclipse
what is this "UP WINDOWS" mod and is it connected to any other modules relays or linuar actuators???
Originally Posted by moda_way
Check one of the interior fuses, I think a 7.5 on the second row down, towards the engine. When installing the green wire, you probably shorted it. Happened to me.
Someone stole "My Garage"
Even though the fuse looks fine, try the following:
1. Look at "map" of fuses, and locate the fuse that controls the above things that you say aren't working anymore.
2. Pull fuse, inspect, and swap with a known-good one (or a replacement if you have one handy).
3. Test to see if the things work again. If they do, the fuse you pulled was bad even though it looked like it was fine. If they don't then did you hear another 'pop' sound when testing? If so, you still have a short. If not, then you might need to look at getting a professional to diagnose the short.
Be aware though... labour rates for electrical diagnosis are often 20-40% higher than regular shop rates (at my dealership I believe I saw it posted as $84 regular, $112 electrical)
More than likely fuse #21 in the underdash fuse box is blown. As mentioned, remove the fuse and test it for continuity with your meter. All of your described inop functions are on the circuit protected by this fuse.
THAT'S THE ONE!!!!
Definitely replace anyway.
Well, I drove over to Autozone during lunch and bought a whole set of fuses. Good to have. Checked fuse #21 and guess what! It was blown!! Dayum you guys are good. Replaced the 7.5A fuse and everything came back on! What a relief!!
Now to call the dealership and cancel my appointment.
Thanks again guys, they forum is invaluable
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
