Help! Code 2138 - TPS Sensor
Old Jul 26, 2008 | 01:25 PM
michael1284's Avatar
I was driving the other day when my indicator lamp turned on. I took it to Autozone today and got it checked out. I wrote down the one code that came up:
P2138 - TPS/Pedal Position Sensor/Switch D/E Voltage Correlation
The autozone guy said it is probably the TPS sensor going bad. Any idea how hard it is to replace this and if it is something that I want to tackle? I've done basics before...I/H/E and some suspension work. I'd say I am a 5 on a lvl of 10.
Any help is appreciated - thanks!
Old Jul 26, 2008 | 03:43 PM
SERVICEADVISOR's Avatar
Acura Owner Advocate
bad idea listening to auto zone guy for tech advise. usually one of three things, weak battery, poor connection or failed connection to or from sensor or pcm/ecm software failure.
if withing 8/84k this issue (except weak battery) is covered under federal emmissions warranty including software update to pcm/ecu.
Old Jul 26, 2008 | 05:30 PM
Just got back from the dealer. He said that because the light turned off, it should be ok for now. I have a feeling it will come back up soon and he said it could be as simple as a software update for pcm/ecu.
However, he says I would have to bring it in for $110 diagnostic in order to figure out what is really wrong w/ it. And that I have to have the code on when I bring it in. Is there any way around the $110 diagnostic thing? I don't want to pay that, then have them tell me it's the $500 throttle body that has to be replaced...
Old Jul 26, 2008 | 07:06 PM
tell them you promise to give them a 100% on the e-survey and "10" rating on the phone survey that you get from acura and they will usually waive it.
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
