Heater not working
Heater not working
I had a garage install a 2way alarm/auto start kit installed yesterday.
Long story very very short, I went in ~11:30 AM and got out ~9PM. It's understandable if it took ~4hrs or so given that there were other customers and the installer had to run here and there to get them done as well for a bit.
The guy put grease marks b/c he didn't use golves on my pillar where side airbag is.
He couldn't finish b/c he didn't have immobilizer bypass and said he'd get it first thing on Monday. (no starter fxn yet)
He KILLED the clutch switch instead doing a bypass. Now the car starts w/o using clutch.
He didn't assemble the plastic pieces together and now whenever I turn the steering wheel, it makes contact w/ the pieces. Thus the noise.
Factory alarm is not disabled, so I have to disarm the factory alarm first then the aftermarket alarm. Or else, factory alarm goes off
Lastly, heater doesn't work even tho I set at HI. (A/C works tho). What can cause this? He burnt a fuse for hazard lights and had to b e replaced. Can something else be burnt for the heater to disfunction?
Thnx guys, I'm going to the garage soon tonight to fix some problems.
When starting w/ my key, there's something wrong if I can start w/o using clutch even w/ a starter installed, correct?
I went to the shop and got it fixed. It took like 10 sec or so. I did not see what he did, but he did something under the hood.
But! last night, i noticed it's not workin properly, again. At high speed (highway), I can feel the heater is blowing nice warm air. However, at stand still or low speed (residential area), it seems the air is just ambivient. I don't want to go all the way to the shop. Does any1 know what do do?
I usually keep all the business cards I get. This one, I ripped in pieces and put them out for good. But I might have to go back to fix this.
Sounds like the heater fan is not working. You might have a blown fuse. The fan needs to work before you will feel any air. At high speeds you are just feeling the outside air blowing over the heater core.
I found something interesting... I put the temp to "high" for a bit. (now mysteriously the heater works :donno Then I turn off the climate control. I get hot air flowing in even when it's chilly outside.
I put it to "low" and turn it off. Then cold outside air flows in like it should. Is there somekind of a valve which control this heated air/cold air mix?
mada51589
05-03-2022 08:54 PM
ahsm
09-09-2015 08:35 AM
