Heated seat switch....
Old Nov 11, 2008 | 10:12 PM
playindagamewell's Avatar
I was trying to find on here if anyone else had this problem, but no luck. My passenger switch light for the heated seat burned out. I took everything appart, and i am not sure if i should replace the whole switch, or just find a way to get inside the switch itself.
The switch works great, it just doesnt light up. I attempted taking the switch appart, but no luck, so i stop messing with it.
My 04 tsx is out of warranty, so I'm on my own.
If you know of any easier way to fix this, lemme know, its bugging me to the extent,
thx,
Old Nov 12, 2008 | 02:58 AM
miked8887's Avatar
Mike D from Ohio
Maybe the lights just out. Do the seats still heat up?
BTW, to get in there, I'm pretty sure you have to remove the center console trim.
Old Nov 12, 2008 | 01:02 PM
neocrynym's Avatar
Do the heated seats still work? If yes, it's just a bulb or bulbs burned out inside the switch:
Remove center console trim, unplug switch, use a small flat tip screwdriver to unlock and take out bulb(s), replace with new Honda bulb(s). You do NOT need to disassemble the switch.
If the heated seats don't work, check your fuses.
Old Nov 12, 2008 | 01:24 PM
Worth's Avatar
here it lcrazyaznl's DIY...
https://acurazine.com/forums/showthr...683#post796683
Old Nov 12, 2008 | 02:09 PM
Originally Posted by Worth
just what i needed, thank you.
the heated seat works fine, its just the light
Old Nov 12, 2008 | 02:14 PM
Worth's Avatar
no problem. seems to be a pretty common problem with the TSX. it happened to me but i was still under warranty so i just had the dealer replace it.
Old Nov 13, 2008 | 11:20 PM
jpvogl's Avatar
you've done the hard part; rest is easy. the bulb to light the switch is a little tiny thing on the side of the switch; there are three in a row that unscrew with a v small screwdriver (half a turn will loosen it, then just pull it out. ) the head is blue. the acura dealer wanted $7; i bought the identical one from the honda dealer for half that. (ditto for the cabin filter; same part number at honda and acura but $10 cheaper.)
Old Nov 14, 2008 | 08:45 AM
lcrazyaznl's Avatar
CL9 ABP
my dealer wanted to charge me 25 dollars per bulb and install.
Went to radio shack each set of bulbs was 2 bucks. Still trying figure out the little lights.
Old Nov 14, 2008 | 11:34 PM
Its funny how the little things start to happen after the warranty is over.
I am gonna give radio shack a shot and seee if they have them, if not, off to the honda dealer than.
Again thanx for the info guys,
Old Nov 20, 2008 | 01:28 PM
Tumby's Avatar
ok... my 05 TSX still has extended warranty, do you guys think the deal will replaced the burnt bulb for me for free?
Thx guys!
T
Old Dec 4, 2008 | 03:46 PM
psengsouriya's Avatar
umm my went out i am few hundo miles after warany can i get it switchd?
Old Dec 4, 2008 | 08:19 PM
TSXGOTME's Avatar
I have a 04 and mine went out about 200 miles after my warranty expired. I went to the dealer they wanted to charge me $97 to check the electrical not even to replace the bulbs. I did a bit of research and found you just need to take out the center console and replace the bulbs in the switch. I bought the replacement bulbs at the dealer for like $2.50 I think I bought a few extra which came in good use cause my VSA switch bulb went out too.
Old Dec 5, 2008 | 07:53 PM
w1lly_g's Avatar
I have the same problem
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
