Fog lights- bulb or connection issue
Old Oct 25, 2005 | 03:42 PM
RMATIC09's Avatar
Hey, i had my foglights professionally installed @ a autobody shop that does dealership work, and had no problems @ all with the foglights, or install. Looked like it came stock, dealership didnt even notice i added them, i added Hoen h11 bulbs, and for a while no problems, untill i switched to the nokya hyper yellows. SO heres my question
1 of the lights dosent come on, but sometimes it does, and sometimes it comes on just randomly.
I tightened up the connections, and everything seemed fine, untill today when it happened again.
So is it the bulb? Or the connection? I mean, i woudlent think it was the bulb on account that it does work when it wants, but how could it be the conneciton if i have had 0 problems, or 0 things that could have caused the problem for over a year?
Old Oct 25, 2005 | 09:11 PM
RMATIC09's Avatar
Now it seems as if the light wont come back on....guess ill have to open it up again tomorrow, or order a new bulb...
Old Oct 26, 2005 | 06:23 AM
yuhoo22's Avatar
John Starks - The Dunk
I have a feeling it might be the wattage of the bulb is too high for the connector. Are you using a bulb with a power rating higher than the stock rating? Take a look at the connector (specifically the two metal connection points where the bulb would fit into) and see if they have burnt. I know this is a major problem for people who put in Xenon look a like bulbs in their head lights.
Old Oct 26, 2005 | 07:53 PM
RMATIC09's Avatar
Well thats the thing, my hoens were fine, and my other nokya works fine, so why only 1. Both sets are brighter then stock, i think i might have just got a bad bulb.
Old Oct 26, 2005 | 08:47 PM
mg7726's Avatar
She said: it's GINORMOUS!
swap the nokya's on each side and see if that happens, then you'll know if it's the particular bulb
Old Oct 27, 2005 | 10:16 AM
RMATIC09's Avatar
well i put back my hoens , and it works fine, so i guess it was a burnt out bulb....
Old Dec 9, 2005 | 10:24 AM
RMATIC09's Avatar
Well, i got the nokyas checked, and both bulbs are fine. I went and purchased Polargs, and now the same exact problem. My driver side bulb went out, i know for a fact, the bulbs are fine.
When the nokya bulb stopped lighting, i put the hoens back in, and no problems from then, till now, over a month.
So why the yellow bulbs? I know it cant be the TSX foglight becuase plenty of members have bright aftermarket yellow fogs.
And my hoens work fine
So i really cant pinpoint the issue @ all.
Are the hoens bulb less wattage? but even so, then why would the yellows work on other members cars, and not mine? and why only 1 foglight? and why only yellow foglights!? im so confused and annoyed... anyone , ideas?
Old Dec 9, 2005 | 05:37 PM
RMATIC09's Avatar
Old Dec 11, 2005 | 08:27 PM
RMATIC09's Avatar
Does anyone think it could be how many radio lights are all out of function?
Old Dec 11, 2005 | 10:23 PM
kyotousa's Avatar
isn't the nokya higher wattage?
Old Dec 15, 2005 | 08:15 PM
rmpage's Avatar
Drives With Hands
No, they're 55 watt H11 bulbs just like stock.
I have this EXACT same problem. It's the right side fog light. I can reach into the underbody and wiggle the harness a bit and it will come on for a little while, but then it goes out again. Seems like a loose wiring harness, or a defective one. In any case, now that I've read this thread I'm thinking it is a problem with the bulbs themselves. Maybe I'll just put the stock bulbs back in.
Old Dec 18, 2005 | 10:36 PM
RMATIC09's Avatar
Yes, but rmpage, now i switched my polargs, from left to right, and right to left,and no issue for a whole week! longest ive gone without any problems with either nokyas or polargs. Im not sure what it was.....
Old Dec 21, 2005 | 06:28 AM
rmpage's Avatar
Drives With Hands
I've isolated my problem to a passenger side wiring harness fault. Gonna have to replace it.
Old Dec 21, 2005 | 08:03 AM
RMATIC09's Avatar
been almost 2 weeks now and no problems, and the problem was solved by switching the driver side to the passanger side and vice versa.
weird huh?
cycdaniel
Dec 17, 2019 10:58 AM
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
ellisd03tls
Sep 8, 2015 04:17 PM
