Flat Tire Causes ABS & VSA Lights to Go On
Old Aug 4, 2009 | 08:31 AM
jhakken's Avatar
I got a front passenger flat the other day on the highway. It went completely flat and I pulled over and put the donut on. When I re-started the car both the VSA and ABS lights came on and stayed on. I've subsequently put on a new tire but the lights have not gone away. What can I do? Can I disconnect the battery to make the codes go away? If I bought a code scanner could I cancel out the codes. Any advice would be greatly appreciated.
Old Aug 4, 2009 | 12:00 PM
nbtx's Avatar
still plays with cars
You may have damaged the wheel speed sensor - find a shop that can read the code (AutoZone, NAPA, other) and repair accordingly. Disconnecting the battery won't make the error code go away.
Old Aug 4, 2009 | 02:05 PM
jhakken's Avatar
Thanks. I'll check it out and post a follow-up.
Old Aug 4, 2009 | 06:59 PM
fanbanlo's Avatar
The manual said we should turn off VSA whenever we put the spare wheel on 'cause the spare wheel diameter will makes the computer assumes you're using same sized wheels.
Usually they will go away themselves, but if they don't, then u should take it back to the dealer.
mada51589
Jan 9, 2025 04:40 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
devinv1994
Sep 3, 2015 01:40 AM
Stu2414
Aug 30, 2015 07:30 PM
