First Gen Sunroof.
Old 08-11-2008, 08:49 PM
JLTSX07's Avatar
First Gen Sunroof.
Hello,
Aside from the common squeaking/creaking issue with the sunroof, has anyone experienced serious issues with their sunroof? I've been noticing that mine has been making some really odd sounds while it's closing. So far everything seems ok, (aside from the odd sounds), but I'm wondering if sunroof issues are a common thing with the first gen TSX's down the road?
Old 08-11-2008, 09:10 PM
mclovintsx's Avatar
I get this cracking sound when I open the sunroof.
Old 08-11-2008, 09:24 PM
JLTSX07's Avatar
Do you open/tilt your sunroof often? Have you had any other issues with it opening or closing, besides the "odd" sounds?
Old 08-11-2008, 09:31 PM
mclovintsx's Avatar
ummm, it's when I tilt the sunroof but I'm not sure if it happens when I open it since I tilt it more often. There's no problem opening it but the sound is annoying. =/
Old 08-12-2008, 09:11 AM
LuvMyTSX's Avatar
Other than the squeaking/creaking/rattling it always does, I've had no problems with my sunroof. I tilt it or open it almost daily for a good part of the year.
Old 08-12-2008, 09:32 AM
jlukja's Avatar
I'm with Jax. Use it often but no problems other than the odd squeak or creak.
Old 08-12-2008, 09:45 AM
Tumby's Avatar
Same here...... the only time I got noises from the sunroof is when tilting it or opening it..... but seems fine so far other then the noises
Old 08-12-2008, 10:05 AM
it's a car-drive it
nj2pa2nc's Avatar
no rattles or creaks with my sunroof-very quiet-
Old 08-12-2008, 12:13 PM
Sweet!
thunder04's Avatar
I've never noticed my sunroof making weird sounds. I'll have to pay attention to it, but so far it's been perfect.
Old 08-12-2008, 05:12 PM
CGP Ebony
xenonhid's Avatar
Arrow
No sounds here, But i do maintain it by wiping down the rubber seals around the moon roof with leather cleaner and find a good amount of debris coming off.
Might want to give that a try.
Old 08-13-2008, 06:42 AM
Oliver!!!
litesout's Avatar
I get the crackling noise when I tilt it too. It concerned me at first, but after a few months I just got used to it. The one in my last car made some odd noises too from the day I bought it, but never gave me any problems. And I use mine almost every day too.
Old 08-13-2008, 09:30 AM
Tumby's Avatar
That is right... never touch it unless if necessary.....
What happened to me was, I used to have a 2.3 CL back in 99, and one corner of the rubber seal around the sunroof popped out after closing the opened sunroof. I took it to the deal to try to fix it, or get the rubber replaced. Back then, I have no idea that the rubber wasn't replaceable, and they have to replace the entire sunroof kit for me. Ever since, the sunroof just keep leaking water whenever the rain was heavy or if in the high pressure car wash. I know a little leak is normal, but what I am talking about is, the drain of underneth the sunroof rubber seal cannot hold the water, and it spilled onto my face
Just not to touch it, as the machanic in the dealship will not be able to put it back to the way that is should from the assemble. Dunno whether it is just the way or just the Honda mechanic sucks!
Old 08-13-2008, 12:43 PM
Oliver!!!
litesout's Avatar
Oh, I should probably mention too that mine's on 08. It entered service in Oct of 07, so it's less than a year old. I bought it CPO in April with 3200 miles on it, and from the day I picked it up, it's made the noise. But it doesn't leak, even in those crazy Florida afternoon thunderboomers, or the one time I took it to a car wash.
Old 08-13-2008, 03:06 PM
Someone stole "My Garage"
curls's Avatar
To be honest, I get a loud "click" or "smack" sound... hard to describe, but I have heard the exact sound before, and I believe it's caused by the relatively thick grease that is in the tracks for the sunroof. If the grease gets trapped and pressured, it "pops" out and makes that sound.
Again this isn't 100% but is my best guess, and I only hear it maybe 10-20% of the time I open or tilt my sunroof (you'll notice that the sunroof uses the same track for both operations... look up next time you are opening it and you'll see the tracks and the grease that I'm talking about).
I wouldn't wipe the grease off though... it's better to have to live with the occasional pop/click, than to have to clean or replace a seizing sunroof track.
Old 08-13-2008, 03:36 PM
Tumby's Avatar
And I have seen people tilt the sunroof up while driving in rain and snow.... this is only my personally opinion, but I think it is a bad idea... as more moisture will get into the track and may wash the grease off in the long run...... sooner to get a seizing sunroof.....
emailnatec
29
09-28-2018 04:27 PM
GWEEDOspeedo
01-15-2016 10:39 PM
RSpyder
09-30-2015 12:46 AM
Quick Reply: First Gen Sunroof.
