Engine Shaking Issue
Old Apr 11, 2011 | 03:31 PM
Eppy712's Avatar
Hey guys, I have been having a problem with my engine recently. I have a K&N Cold Air Intake and a Skunk2 Catback, everything else in the engine is stock. When the car is in either neutral, park, or reverse the engine is fine. But when the engine is warmed up and in drive the entire engine shakes all the way back to the tips of the exhaust. BUT the shaking of the engine doesn't shake the car or anything WEIRD. I get an occasionally misfire if I hit the gas at a certain point when the RPMs are going down.
Any help would be greatly appreciated!!!
Eppy712's Avatar
Oh btw its an 2005 Acura TSX
Old Apr 11, 2011 | 03:35 PM
swoosh's Avatar
takin care of Business in
Are you getting a check engine light ?
my guess is the O2 sensor or the spark plug/coils going bad....but you should have the check engine light codes read....
Old Apr 11, 2011 | 03:40 PM
Eppy712's Avatar
no, I'm not getting any codes or a check engine... I'm pretty sure I have had this problem before the modifications.
Old Apr 11, 2011 | 10:08 PM
huludicidal's Avatar
Almost Doctor
have you noticed a decrease in fuel economy? It sounds like you're running rich, likely due to a malfunctioning O2 sensor. Your first check should be the spark plugs. If they're black or wet, you're running rich. If they're white, the mixture is fine.
Old Apr 19, 2011 | 09:09 PM
Riddim's Avatar
9th Gear
Engine Shake.
I'm not a mechanic but I had a similar problem. My engine would shake out of control when I was in drive and stopped at a red light. Once I started moving the shaking stopped. I brought it to the dealership and ended up getting the engine mounts changed. No more shaking. I have an 2004 TSX stock. 162,000 miles.
Old Apr 20, 2011 | 03:47 AM
SoCaliTrojan's Avatar
Let me help you!
If the engine shaking is not shaking the cabin, I'd suspect the motor mounts are bad. The motor mounts connect the engine to the frame, so you should be feeling something. It sounds like the engine is shaking, along with whatever parts are connected to it (header, to catalytic converter, to exhausts). All of those parts are attached to the car by hangers, so they can freely shake without shaking the car.
Old Mar 16, 2015 | 10:09 AM
sema2o9's Avatar
same here
I got same problem but my car is auto, shops say they dont know why
Old Mar 22, 2015 | 04:44 PM
Tangoman's Avatar
Check your front motor mount. Suggest that to your shop.
01CLOwner
Oct 9, 2015 01:07 PM
carz0159
Sep 20, 2015 06:11 PM
redsox68
Sep 16, 2015 06:18 PM
MikeYutkin
Sep 10, 2015 10:13 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
