weird starting issue this morning-2006 auto
Old Mar 23, 2015 | 07:13 AM
kipsy's Avatar
car stumbled when starting this morning, held key in starting position and rpms gained and finally started.
all fine- 15 mile drive, turned off at work, and restarted 3 times fine.
never ran low on oil, oil changed every 3k miles, 103k miles. no lights.
Old Mar 23, 2015 | 08:53 AM
TexasHonda's Avatar
Weak battery and/or corroded battery terminals should be investigated if starter action was irregular or slow.
good luck
Old Mar 24, 2015 | 10:13 AM
mrgold35's Avatar
mrgold35
You can take you TSX to someplace like interstate battery to double-check to make sure that isn't the problem. I had low fluid levels in two of my cells on my battery and interstate filled them up for free. The TSX doesn't like starting with low cranking amps.
Old Mar 24, 2015 | 10:22 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
As mentioned above - check your battery connections for both corrosion and tightness at the battery. Also check battery cables at the other ends as well. How old is the battery? Might be time for a new one.........
Old Mar 24, 2015 | 03:46 PM
kipsy's Avatar
battery was new in december after last interstate give it up at 30 months. new one was 1/2 price. cable connections good and clean. no issues since.
Old Mar 25, 2015 | 07:56 AM
mrgold35's Avatar
mrgold35
I was thinking about getting the INNOVA 3721 Battery and Charging System Monitor for $14 on Amazon. A battery and charging system monitor might be a good way to double-check you don't have a power draw issue if the car sits for a while. I think it can also give you a real time read out of the volts during start-up to see if the power is a little low. I've had battery issues on all 3 Acura vehicles that required replacement of batteries, firmware updates, alternator replacement, and module replacement.
LINK:
Amazon.com: INNOVA 3721 Battery and Charging System Monitor: Automotive Amazon.com: INNOVA 3721 Battery and Charging System Monitor: Automotive
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
andysinnh
Sep 5, 2015 11:38 PM
NSolace
Sep 3, 2015 08:14 PM
