electrical probleme
Old Jan 3, 2007 | 11:41 AM
snake 2's Avatar
8th Gear
Question electrical probleme
Hello im new to the site and I need some help from the team here.
I have 04 tsx and Ive put a sub mtx thunder 9500 RMS Power Handling 1000 watt whit MTX TA92001 2 Ohms 2000 Watts RMS amp whit 1 farad. Know it seem that when I put the volume up (15) and increase the bass boost a lill the light, inside and outside are blinking. Im planning to put also the pioneer avic-n3 I don’t won’t to damage any electrical systems. Is there a way to solve this issue?
Old Jan 3, 2007 | 12:09 PM
wickedk24's Avatar
Oh well it's
Battery can't handle it
Old Jan 3, 2007 | 12:42 PM
Dan Martin's Avatar
Photography Nerd
I'm sure the stock alternator wasn't designed to put out 2KW of extra power. I bet you'll need a higher rated one.
Old Jan 3, 2007 | 12:57 PM
Tsx536's Avatar
Rep'n Taxbrain.com
You'll need a high output alternator and maybe even a deep cycle battery depending on if you ever want to listen to your beats with the car off.
Old Jan 3, 2007 | 01:05 PM
peter_bigblock's Avatar
C'mon, man! Row yer own.
I agree with that -- it's the alternator (battery doesn't provide power while the engine is running, I believe). The stock alternator is 105 amps and, if I remember from JTso's pulley write-up, about 14.35 volts max. That's about 1,500 watts max.
You need a high-current alternator. Moderators, this thread might be better served in the "Audio Visual" section.
Old Jan 3, 2007 | 02:53 PM
snake 2's Avatar
8th Gear
do you guys know a model of high output alternator that will fit for the tsx 04
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
rboller
Sep 23, 2015 02:49 PM
