Electrical problem? please help!
Old Oct 29, 2009 | 02:21 PM
Howard911s's Avatar
HOWARD911S
Have a 2004 tsx with 92000 miles on it. Yesterday the ENGINE light came up and the side airbag light flashed for a few seconds, then the airbag sign went off but the check engine line stayed on. I stopped the car to make sure gas cap is snug which it was. After couple hours.. the orange Engine light went off.
Last night on the freeway driving, the car suddenly lost power for 1-2 seconds on the freeway, headlight off, stereo off, everything off, then the power came back on again. The engine did stop for a fraction of second then came back on and I was able to drive home without incident.
However, this morning when driving, all the light started to flash for 2 seconds then went off cept for the Engine light.
Now the car feels fine driving, I don't think its the battery problem. Just short of spending $$$$$$$$ to have mechanic hook my car up to check the problem, any suggestions or fixes?
Old Oct 29, 2009 | 07:49 PM
RogerPodacter's Avatar
So, do you like...stuff?
To me i might think alternator is going since your car lost power. That would certainly cause electrical issues. But i'm just guessing.
Old Oct 29, 2009 | 08:17 PM
litesout's Avatar
Oliver!!!
Alternator wouldn't cause the headlights to go out all of the sudden and the engine to stop. There's also a different light for that.
I'd start with the fuse box connections. Just be very careful. They're hot even when the key's off. After that, check the battery connections and the engine grounding strap. If all else fails, check the ignition switch. My old Accord did something very similar (except the headlights, that's odd). Turns out the ignition switch was corroded and wasn't making contact anymore.
Old Oct 30, 2009 | 12:05 AM
Howard911s's Avatar
HOWARD911S
Hmmm i found out one thing very strange. I'm thinking its electrical cause when I plug in my garmin GPS it tends to have flashy dashboard more but after I take it off everything works perfectly......As long as I dont touch that darn cigarette lighter........Guess I'll have them check it out........thanks both for replying.. maybe fuse or something like that...
Old Oct 30, 2009 | 06:28 AM
HoRRo's Avatar
iVTEC no koe
Check your ground connections (mainly the battery->chassis one). I believe there were others with similar issues.
Old Oct 30, 2009 | 10:48 AM
Howard911s's Avatar
HOWARD911S
So you guys recommend disconnect the battery and reconnect?
Old Oct 30, 2009 | 11:52 AM
poltergeist's Avatar
Try this...on page 2 http://www.in.honda.com/Rjanisis/pubs/SN/B080400.PDF
Old Oct 30, 2009 | 11:56 AM
Howard911s's Avatar
HOWARD911S
Originally Posted by poltergeist
THIS
SOUNDS
LIKE
IT
but I dun have any of the cable, testing equipment what not mentioned in the bulletin lol..... wonder how much shop will charge for all these.... and if the cable is the culprit how much that will be
Old Oct 30, 2009 | 12:45 PM
Chelsea John's Avatar
How old is the battery. I had, some years ago, a cell short out in the battery. All my lights went out whilst i was driving at night. No warning..Since then replace my battery frequently. A $100 dollar part and five mins to change out saves so much grief in the long run.
Old Oct 30, 2009 | 12:48 PM
Howard911s's Avatar
HOWARD911S
I would REP you if I could, after thinking about it, I just drove my car to the drive way, popped the hood.. VOILA... two cables. + one was clean shiny since it had the red cap over it. The - cable, no protection had tons of white residue, powderlike substance over it. I'm assuming its dust + oxidized metal parts from all the electric charges over it. I disc the - cable and wiped the battery connector clean.
BUT the round copper head of the - cable was covered with the white powder inside and out, I used screw driver, clothes wiped it as clean as I could and put it back to the battery, heard some electrical buzz sparks which I assume means pretty decent connection and start the car. Lights were gone and did not appear, well at least for 5-10 mins. Hopefully my little episode means It just needs cleaning and the connection was bad. THanks again for the response, Ill post back here for further.
Old Oct 30, 2009 | 12:49 PM
Howard911s's Avatar
HOWARD911S
Battery is about 40 to 50k miles...that said.. acura/honda battery does suck, first one went out at 40k lol....I'm at 92k now.. I'll change out the battery too just to be sure on my next scheduled service Thanks for the advise, simple but sound as well.
Old Nov 3, 2009 | 12:39 PM
kwyatt318's Avatar
i've had this problem earlier this summer. i took it to acura and they could never figure out the problem even when i showed them the TSB about bad ground connection. best bet is to replace the ground/negative battery cable. go to autozone and buy it for 5bucks. after i replaced it i've never had the problem again.
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
rboller
Sep 23, 2015 02:49 PM
