DTC code P0718: Mainshaft speed sensor (intermittent failure)
Old Oct 22, 2008 | 09:45 PM
jmathew34's Avatar
Sup all,
Trying to see if anyone has had this fault code come up?
This code has come up now 3 times in the last 6 months...I've cleared it the past 2 times but now it looks like I should take a look into this...
Anyone have any idea where this sensor is located?
Any help would be appreciated
Old Oct 22, 2008 | 11:29 PM
240sx acura tech's Avatar
acura master tech
well thats a transmission code. electric, i don't think its internal.
Old Oct 23, 2008 | 10:33 AM
poltergeist's Avatar
Mainshaft speed sensor is mounted into the trans case, at the left/rear of the transmission.
Old Oct 25, 2008 | 04:36 PM
jmathew34's Avatar
found my helm's, bought the sensor it's about $80 from acura stealership. Fairly easy to change out. Pg. 14-200 for those with the helm's manual...
Old Oct 26, 2008 | 01:07 PM
Miamicarfan's Avatar
jmathew34:
How many miles does your TSX have?
When this problem came up, is it a flashing or solid light that lights up in the dashboard?
Old Oct 27, 2008 | 02:54 PM
jmathew34's Avatar
issue started for me probably with around 90-100k on the car. I currently have little over 131k on the car. The VSA light comes on, the D in the gear selection area of the gauge cluster flashes and your check engine light comes on...DTC code P0718 is what I got when I retrieved the error code...
Old Oct 27, 2008 | 08:13 PM
When the speed sensor goes bad, the miles that your odometer registers will be inaccurate right?
I think having an incaccurate odometer to measure the miles traveled is the only consequence of having a bad speed sensor right?
Does anyone know if there are there any other problems that can arise from a bad speed sensor? I don't think it will damage the transmission.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
ghuns
Sep 16, 2015 04:26 PM
DS2000TL
Sep 9, 2015 09:26 PM
