Doors lock randomly
Originally Posted by Knifey
Early '05. Why?
Make a hole, coming thru!
Not yet deliberately. It replicates on its own however.
Originally Posted by davidspalding
No rhyme or reason? E.g. always at highway speed, or only when I'm driving alone (the usual ghost sighting phenomenon), only on weekdays....
Let me help you!
Originally Posted by Simba91102
Any chance it's an 04?
Your door lock actuator may be dying. Take it to the dealer if you still are under warranty.
still plays with cars
Anyone had this happen, while driving along the doors just periodically lock? Just started yesterday, kinda weird.
Originally Posted by nbtx
Just a WAG - it happens at the same location, right? If not, please provide more information. Maybe some outside RF source is interfering with the key fob receiver.
What does this have anything to do with the original question? Unless you have a TSB that relates to the 04, it shouldn't matter.
Figures, I passed the 50k mark about two weeks ago. Could be the actuator, as has been described in other threads, I've noticed that the driver's door is slower to unlock than the rest, but it doesn't stick or not work. And it's all doors that lock, haven't taken a look at the schematic - it just started two days ago - but if the all-doors-lock circuit can be triggered at the actuator it might be worth further investigation.
(Don't laugh, years ago, my avionics shop spent several days trying to figure out why an HH65 helo's mission computer would reject a LORAN input in flight, but everything checked out on the ground, and the problem persisted even after replacing every box/unit we could. Finally, on a hunch I checked wiring. Sure enough, this was a relatively new airframe, and an antenna BNC connector was missing a bushing, so the conductor was shorting to the shielding during flight (with major vibrations). On the ground, everything worked fine. We partied the night we fixed that puzzle.)
No, no pattern I've been able to discern. Time of day, geographic location, in motion, at rest, nothing reproducible so far.
... All doors are locked one of three ways, the master lock switches (driver and front passenger doors), the driver's door lock pin/post, and the keyless entry remote.
Let me help you!
It wasn't an unreasonable question. And he explained his question later. Simmer, dude.
He asked "any chance it's an 04?" which implies that 04's have that problem. His successive threads still don't help the OP by providing more information related to the problem.
Let me help you!
Now, if your driver's door lock doesn't affect the other doors, then disregard my idea. (I never lock/unlock my doors manually, so I don't know.) I assume though, that if I were to lock the driver's door with my key, it'd cause the other doors to lock as well....
The 04 models seem to suffer from a growing (naturally, as they age) list of problems (of all sizes and types), so I was just curious. Judging by some of the threads on this forum, they seem to suffer from a major case of the first year blues. (And to all you 04 owners out there with trouble free (relatively) cars, please don't take it as a burn, just an observation).
Originally Posted by SoCaliTrojan (sigline)
Is this post in response to someone having problem with a TSX? If so...
Any chance it's an '04?
And before you ask why it's relevant, it's an okay question to ask regardless of the problem:
Could someone please confirm whether or not locking the driver's door with the key will lock all doors. I can unlock the driver's door with the key on one turn and then unlock all doors with a second turn. However, I can only lock the driver's door with the key, two turns does nothing.
I believe that locking with the key in the driver's door locks all doors. Check your manual, "Door Locks," around page 128 or 129: "All doors can be locked from the outside by using the key in the driver's door." Unlocking with the key, the first twist unlocks the driver's door, second twist within a few secs opens the rest. This is changed with the "door lock mode" (p. 111).
Another thing you can try is the power window function ("Opening/Closing the windows with the key," around page 149). With the car locked, turn the key once to unlock. Turn the key a second time and hold, and all doors unlock, AND all four windows start down. They continue down as long as you hold the key in the turned position. NOW ... turn the key the other way to lock. Turning and holding the key a second time, all the windows will close (p. 129).
If you're not seeing these behaviors, DEFINITELY something screwy. Bear in mind that I've got a 2006, not 2005, and I've only looked in the 2006 and 2007 manuals.
Hope this helps....
Hope this helps....
Let me help you!
This makes sense...if the driver wants to lock his door, he probably is about to leave his vehicle in a parking lot or wherever. Thus, the car should lock all the doors along with the driver's door. It would be silly if only the driver's door locked, and the car left the other doors unlocked.
Thanks for the manual ref. and thanks SoCaliTrojan for trying it out. The behavior seemed wrong but I don't recall ever (un)locking the door with the key so I wasn't really sure. And just because it seems wrong don't make it so, like the inner door latches not unlocking the door. Seems wrong to me, two years now and still haven't gotten used to it.
I already know something is screwy, hence the thread. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Update
Pulled out the service manual on Saturday to isolate the bad component. Went thru the diagnostic checks with my multimeter and oddly everything worked out. Somewhat disappointing actually, as something is obviously wrong, but all doors locked with the key or lock knob - which wasn't working two weeks ago. Since Saturday the car hasn't locked on it's own, very strange. Glad it's a non-issue, presently, but skeptical it will last.
Sometimes problems disappear after troubleshooting, because you've jiggered things about a bit. Used to see it on avionics frequently, the very act of removing and reinserting black boxes cleaned contacts and chased the gremlins away.
boost owns
On a related note, the last week or so I've noticed that once I remote unlock my car, I have much less time to get the door open before it re-locks itself. We're talking under five seconds at this point. I know that can't be right. Any idea what's screwy there? I'm getting a heated seat backlight bulb changed some time in the next week or so and I plan to ask my dealership to take a look then, but I'm curious if anyone else has experienced this.
Check your relock interval in MID (not sure what year you have). It's adjustable. Maybe you're using a different remote key fob? If they're liniked, you could be using "Driver 2" where before you've been using "Driver 1."
I'm pretty sure the problem is with the actuator. My dad had a similar problem on a Jeep Grand Cherokee some years back. The problem is that when you unlock the doors in a manner that uses the actuator (fob, "master lock" switch on either the driver or passenger side) the lock isn't pushed up all the way. I haven't seen the TSX actuator but the Jeep used some sort of electro pneumatic solenoid. There was a rubber diaphragm involved and the thing is, this diaphragm just naturally wanted to be either all the way in or all the way out. It didn't like being in the middle. In that case, there was an air leak in the pneumatic part of the actuator that would cause the diaphragm not to move the full travel leaving it in the middle. Sometimes it would pop back in locking the doors, and other times it pop out, unlocking them.
I currently have a faulty actuator in my front passenger side door and what I'm getting is the lock not popping all the way up or down when I use the fob. It hangs in the middle. If the same thing was happening on the drivers side, it's probably hovering right around the point where the switch engages to lock or unlock the rest of the doors when you pull up or push down on the peg.
Solution: tell the dealer you need a new actuator put in. You may be able to get them to do this for free despite your mileage. I'm currently scheduled to have mine fixed on Monday. I just called and told them "I need a new actuator" and they said ok. I didn't even bother explaining why I thought that. I assume they've seen quite a few of these at this point and just figured I was probably right.
boost owns
MrHeeltoe
20
02-23-2023 01:54 PM
soupi
14
11-15-2015 11:15 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
