Door Lock Actuator Replacement.
Old Feb 26, 2012 | 03:02 AM
JeffTSX021's Avatar
Hello All,
The door lock actuator went out on my 07 TSX with 52k miles, and I was just wondering what people have been paying to have this repaired from Acura?
Also, I think I will go to Honda instead, since they're always cheaper. Will the Honda techs know how to do this repair, or am I better off going to Acura?
Thanks!
Old Feb 26, 2012 | 04:11 AM
oligoodday's Avatar
acura/honda dealers will charge u about $120-$160 for labor + the cost for the actuator... you can pick up the part for $15-$30 just about anywhere... its not that bad to replace yourself. here'e a diy thread... https://acurazine.com/forums/1g-tsx-problems-fixes-128/diy-how-replace-front-power-lock-actuator-690275/
Old Feb 27, 2012 | 07:26 AM
nj2pa2nc's Avatar
it's a car-drive it
call both places-get prices and decide wow-you seem to have your share of problems with your tsx. Luckily I have had excellent luck with mine
Old Feb 28, 2012 | 03:37 PM
JeffTSX021's Avatar
I know!! Mine definitely hasn't been as problem-free as yours! Have you had to get a door actuator replaced yet?
I found some DIY's - I'm going to give it a shot before taking it into Honda
Old Feb 29, 2012 | 06:12 PM
NwTSXmt's Avatar
Its easy just take your time....
Old Feb 29, 2012 | 06:53 PM
nj2pa2nc's Avatar
it's a car-drive it
no-hoping it continues to work (knock on wood) still on the original brakes.
Old Mar 3, 2012 | 10:56 PM
mdechgan's Avatar
Both the front door lock actuators of mine went kaput. I went to the junk to get some and they wanted like $60-$70 each per side. I was like what? The dealer sells them for $35 each brand new. They are the exact same ones as the 7th gen accords.
I suggest before you do the work buy the bushings;
72141-SD4-004
72181-SD4-004
right and left bush joints about $6 each retail. These bushes connect the door locks to the handle. To change the actuators you have to remove the metal link from the handle but 9/10 when you remove it the bush will break if the the car is old and plastic is brittle.
72141-SD4-004BUSH, R. JOINT
Old Mar 7, 2012 | 11:21 AM
narutobear's Avatar
Someone made a detail video recently in hd
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
