Door Actuator
Old May 19, 2008 | 04:50 PM
Roci's Avatar
Door Actuator
Hi everyone like many of you, my Door Actuator finally gave in. I know there is a lot of threads about the actuator already but I wanted to see how many of you have had this problem, so please If you have had this problem, raise your hand.
1. Roci 05AT TSX (57,000 miles)
2.
3.
4.
5.
Old May 19, 2008 | 04:53 PM
xenonhid's Avatar
CGP Ebony
2. Xenonhid 05 TSX (actuator when out at 26,000 miles, fixed for free under warrranty)
3.
4.
5.
Old May 19, 2008 | 05:04 PM
PACman's Avatar
2. https://acurazine.com/forums/showthr...+lock+actuator
3. PACman
4.
5.
Tsx536's Avatar
Rep'n Taxbrain.com
2.
3.
4.
5.
2. PacMan
3. Tsx536 04AT TSX (At 47K miles Front Right went bad, at 85K Front Left Went bad) Also installed new acutators for about 3 other forum members
4.
5.
Basically, it seems to be a very common problem!
Old May 19, 2008 | 05:06 PM
xenonhid's Avatar
CGP Ebony
Probably should have made this thread into a Poll, rather than a list.
Old May 20, 2008 | 11:15 AM
Roci's Avatar
I don't think I can create a poll that is why I did the list.
I will be taking my car in tomorrow I was hopping a lot more of you would add your name so that I can take it to them to see it is a common problem, and maybe get it repaired with a discount or maybe they would consider replacing it under warranty in good faith, (mine is expired), and eventually it would help others with the same problem. I know it is an easy fix but I have 0 mechanical abilities, and would probably end up breaking something els.
Thanks to those of you who put your name on the list.
Old May 20, 2008 | 11:22 AM
wong05tsx's Avatar
Need more room in
2. PacMan
4. Wong05tsx (Pass. side ~ 30k miles)
5.
Old May 20, 2008 | 11:44 AM
dom's Avatar
dom
2. PacMan
5. dom (Pass. side ~ 65K miles)
Old May 20, 2008 | 11:52 AM
Marathon's Avatar
2. PacMan
6. Marathon (driver side ~44k)
Old May 20, 2008 | 01:40 PM
thunder04's Avatar
Sweet!
2. PacMan
7. thunder04 (drivers side ~ 60k)
Old May 20, 2008 | 01:42 PM
LoveMyTL-S's Avatar
2. PacMan
7. LoveMyTSX - Drivers side 70k miles
Old May 20, 2008 | 02:31 PM
LukeaTron's Avatar
2. PacMan
8. LukeaTron - Front-right and left-rear both need to be replaced @ 58k. Been to busy to take it in. Dealer told me they see a lot of this in the TSX and RL. Same part maybe?
Old May 20, 2008 | 03:27 PM
TSXsurf's Avatar
NBP/EBONY/6MT
2. PacMan
9. TSXSurf - driver's side @ 40k miles
Old May 20, 2008 | 03:31 PM
LuvMyTSX's Avatar
This is one problem I've not had yet.....I probably just jinxed myself.
Old May 20, 2008 | 05:28 PM
neo661's Avatar
2. PacMan
10. Neo661 (04 TSX. went out at about 80K, there are alot of threads on this...its really easy to install...cheap part too...about 18 bucks @ www. oemacuraparts.com )
Old May 20, 2008 | 07:52 PM
Miamicarfan's Avatar
2. PacMan
Today 4:31 PM
11. Miamicarfan (05 TSX. went out at about 33,000. Drivers side door.)
Old May 20, 2008 | 10:30 PM
chhimp's Avatar
2. PacMan
Today 4:31 PM
12. chhimp (04 TSX went out at 70k. Driver's Side)
Old May 22, 2008 | 11:11 AM
iVTECdailyy's Avatar
05 Crew
2. PacMan
Today 4:31 PM
13. iVTECdailyy (05 TSX, went out at 27,000. Front Right Side)
Old May 22, 2008 | 05:04 PM
EscaBoi's Avatar
My driver side actuator was replaced at 57k km according to the service records on my car, which was before I got it. Mine is '05 currently with 72k km
Old May 22, 2008 | 07:44 PM
xakep's Avatar
2. PacMan
Today 4:31 PM
2. PacMan
14. XAKEP (04 tsx, 93000, both front stick, driver and passanger)
Old May 22, 2008 | 08:54 PM
evenq's Avatar
2. PacMan
15. Evenq (Driver Side 05 TSX, 44k)
Old May 23, 2008 | 02:24 PM
PhiDelt's Avatar
2. PacMan
16. PhiDelt (Justin Reitsma) '05 TSX driver door, 67,000 kms
Old May 23, 2008 | 03:23 PM
tdottsx's Avatar
my door makes a weird clicking sound when I open it. I'm gunna get it checked, is that what u guys r talking about?
Old May 23, 2008 | 03:31 PM
peterjedi's Avatar
2. PacMan
17. peterjedi 2004 TSX with 61,000 miles.
My actuator was working on and off for about 1.5 years before I brought it in.
Old May 23, 2008 | 05:14 PM
wickedk24's Avatar
Oh well it's
2. PacMan
18. wickedk24 2004 TSX (Driverside went out at 75,000 Passenger at 50,000)
Old May 23, 2008 | 08:00 PM
green_henry's Avatar
2. PacMan
19. green_henry 2005 with ~30k
Old May 23, 2008 | 08:41 PM
eve's Avatar
eve
2. PacMan
20. eve - Driver's side, 2004 ~35k miles
Old May 24, 2008 | 10:12 AM
Ol'DoogyDoggy's Avatar
2. PacMan
21. Ol'DoogyDoggy - Driver's, 2005 ~35K miles
Old May 24, 2008 | 09:52 PM
Xtremespeed2102's Avatar
2. PacMan
22. Xtremespeed - Driver's, 2004 - 40k
Old Jun 1, 2008 | 09:57 AM
dP-'s Avatar
dP-
2. PacMan
23. dP21 - driver, 2005 ~50,000 KMs
Old Jun 1, 2008 | 11:16 AM
xaznperswaesonx's Avatar
2. PacMan
24. xaznperswaesonx 04 tsx passenger @ 30k ish
side note: its a common problem because the door lock motor itself uses plastic internal gears
Old Jun 1, 2008 | 07:50 PM
sabby's Avatar
2. PacMan
25. sabby- 2004 passenger front @ 64,000 miles
Old Jun 2, 2008 | 12:02 AM
lookin_badass's Avatar
2. PacMan
26. lookin_badass 2005 passenger front @ 60300 miles
Old Jun 6, 2008 | 03:47 PM
cober319's Avatar
Brum Brum!!
2. PacMan
27. cober319. 2004 driver and front passenger starting to go slow 41,000 miles
Old Jun 7, 2008 | 12:26 AM
kaliraver69's Avatar
I think I have had all my actuators changed out of all me doors. They are purely junk especially when they start wheezing. Definitely add me to the list.
2. PacMan
28. kaliraver69 All four doors, wheezing and one died completely 4x,xxx miles
Old Jun 7, 2008 | 10:40 AM
ying's Avatar
2. PacMan
29. ying- 05 drivers side ~70000Km
Old Jun 15, 2008 | 12:19 AM
xakep's Avatar
Replaced both front actuators today. First door was learning, hence took a bit long time. the second was done quickly and easily.
Old Jun 15, 2008 | 01:26 PM
luder917's Avatar
SSM FTW
2. PacMan
29. ying- 05 drivers side ~70000Km-
30. luder917 - replace drivers door ~65k, passenger going out
Old Jun 15, 2008 | 01:41 PM
bluexcrush's Avatar
2. PacMan
31. bluexcrush - driver door ~ 95,000km, $100 P&L
Old Jun 27, 2008 | 11:46 AM
coronad0's Avatar
Panzerkampfsnowzen
2. PacMan
32. coronad0 - '04 TSX, all the doors, right at about 75k.
