Disappearing oil
#121
Someone stole "My Garage"
Have you ever heard of a PCV so f'd up that you get 1 quart every 600 miles (six hundred, not six thousand miles) in the catch can? Not bloody likely!
#122
Didn't you read my post? They replaced the PCV waaaay back when and it didn't help at all. Others with the same problem had theirs replaced as well with equally uneventful results.
#123
#124
not to say im an expert ,im not ... but find it too coincendental that CLs blew oil through the crank vent tube and u guys have the same disappearing oil problem but its from out of round cylinder walls ? sounds alot like replacing my tranny 3 xs with a new one and ecu that has the same inheriant defect resolved our problems .... oh and replacing your short block can and probablly will reduce your cars resale value...
I'm sure you know Honda/Acuras, but don't pretend that you know THE cause of THIS problem when you don't necessarily have the experience with it. I'm not trying to be disrespectful to a Senior Mod -- I already said I don't care if you're new or not -- I'm trying to get across to the other members that the problem here isn't always fixed with a cut-and-dry answer.
And, what's worse for resale value: a car that burns 8L of oil between oil changes (that's 1.5 oil changes worth of oil!), or a car that has a brand new, updated, dealer-installed bottom-end with all new valve seals, gaskets, and as such, about 1/2 of the engine mileage as the odometer reads?
#125
so recently it turned out I had a very very small oil leak coming from an o ring between the crankshaft and the pulley. I had it changed and I will post later to see if there is any change in oil consumption.
PS. The oil leak was very minimal (a small drop per week maybe in the garage) but maybe it was leaking more under pressure while not parked.
#126
I don't care if you just joined or have been working on Hondas for decades. I'm giving you MY experience which is 1st hand knowledge and not based upon a difference engine altogether.
Again, the PCV was replaced on mine and did nothing at all. Then the shortblock was replaced as per HONDA and the problem was solved. You'd think they would rather not spend thousands in labour and parts to replace an engine when they would be able to replace a $25 part instead. Apparently they know that replacing the small-$ part does nothing for this problem, and they know that replacing the large-$ shortblock does fix this problem.
#128
I know that all engines burn some oil. My 'new' engine hasn't burned more than probably 250mL per 8000km (a pint? per 5000 miles) since the new shortblock. The stuff that was burned is fine -- it's burning oil quarts/litres at a time that's not. There's a HUGE difference between burning 250mL and burning 8L in the same timeframe. One is normal. One isn't.
#129
#130
For the benefit of others who have TSXs using a moderate amount of oil between oil changes.... Replacing the PCV valve may drastically reduce the consumption. Our 2004 TSX has about 71,000 mile on it. I have had the oil and filter changed every 5,000 miles or every 6 months, whichever came first, since it was new. About 12,000 miles ago I noticed the car was using a noticable amount of oil between oil changes... I watched the oil level carefully and found that the car was using 1 quart every 2,500 miles. I had the PCV valve replaced by the dealer when I last had the oil and filter changed.... We have now driven 1,250 miles since the PCV valve was replaced. The oil is at exactly the same place on the dipstick that it was when I checked it the morning after the oil and filter were changed....A big thanks to TypeR for insisting the PCV valve was the culprit. On a side note...I've always checked my oil the morning after the dealers have changed it and the oil has always registered about 1/4 inch above the full mark. Is this too much oil? Does this cause crankcase pressures to be too high and, perhaps, contribute to the premature plugging of the PCV valve?
#131
#132
There is no recommended interval. This is kind of funny. The three Acura dealers I have gone to for service on our TSX have all recommended service items/intervals that are not called for in the maintenance manual....fuel injector cleaner...flush cooling system every 40,000 miles or so...change manual transmission fluid every 30,000 miles etc. I had to insist that the dealer replace the PCV valve. They normally do not even stock the valve so I had to wait a week to have the oil and filter change so that they could replace the PCV valve at the same time.
#133
#135
I can offer an update on my experience. Oil use dropped to near zero for about 5,000 miles after changing out the PCV valve. Then it rose again although not to the previous level... It is now using about a quart every 5,000 miles. About half the amount it was using before. But, the oil use in our TSX appears to be a function of the number of cold starts. Just got back from a 2,399 mile road trip. Used only about an eighth of a quart in those 2,399 miles. The car is not leaking oil... At least there is no oil on the floor in our parking space. Maybe it is burning out of the valve guides when the engine is still running cold after start up. Haven't seen any smoke though.
#137
2004 TSX NAV 5AT MSM
Is there a PCV valve on a 2004 TSX? I asked my service advisor at my local Acura dealer and he didn't think there was. But since they aren't always right, I thought I would ask.
#138
I just read through this thread. I have some ticking when I first turn on the car, thought it was maybe the caps needing adjustment.
Somewhere in this thread it said it could be the PCV making that ticking, which sounds like caps. The ticking fades fairly quickly and is not present after the engine warms up, only from first cold start.
Is it recommended to change the PCV? Or can we just clean it during the next oil change? I have an 06 TSX with ~125k miles.
#139
The noise at start up is most likely the valves; assuming they weren't, they should have been adjusted at around 105K (same interval as the spark plugs). It could also be the fuel injection; it can make a ticking noise when cold that mirrors valve clatter.
#141
Geez this sucks. My 04 6MT has 149k on it now and I think I might burn 0.25 quarts over 9k miles? Very low oil consumption trates. Now, I basically drive at 3-4k rpm on the highway all day so I don't sit up there in the rev range.
But, I'm surprised so many people are chiming in with these issues. It was my understanding that the k-series motors were a huge improvement over the older H/B/D series stuff and oil consumption was greatly improved.
My H23 in my older Prelude burned oil pretty quickly but that was up in the 150k mile range as well. I don't have much to add to this thread other than check your oil regularly and drive it until it dies.
Moving to 10w30 should NOT help and all it will do is increase your oil pressure when the car is cold.
#143
The 04 TSX does have a PCV valve; the engines in all TSX's are essentially the same, with a few internal and external changes in the 2nd gen engine (oil filter location being one). There is no recommended interval for PCV valve replacement, but it's so easy (and cheap) to replace, I see no reason not to replace it as often as your driving style might dictate (whenever that is). All highway driving, maybe every 100K or so, mostly around town, I'd do it more often.
#144
Don't assume the 1st gen and 2nd gen cars are comparable. They're considerably different, and in my opinion, so different that the 2nd gen car probably should have had a different name (I've had both models. An 05, 07, and have an 010 now).
#146
5th Gear
#147
I still use oil (1 - 2 quarts/6,000 miles), and it still seems that I use oil when I vtec a lot, especially when in higher gears with heavy loads/at higher speeds. 6MT, now with 155,000 miles, and the car has been using oil like that since it had 85,000 miles. Oil consumption test showed that when I drive quietly, not on the highway, during the winter, the car hardly uses any oil.
For the past two years, I've been adding Mobile1 0w40, to replace what's used between oil changes. I don't know if it's helped, but I doubt it's hurt, and I feel better.
Yesterday I passed another emissions test, again with no problems, but I did this one 8 months early, so regardless of how much oil the car uses over the next, say, 80,000 miles, it will still be licensed.
IBankMouse
06-13-2020 12:53 PM
