Buzzing noise from engine when turning -VIDEO INSIDE-
Old Oct 28, 2009 | 07:05 PM
awinn's Avatar
My tsx has been having a low whining noise from the engine for the last 3-4 weeks (wasnt there before). You can hear it at low rpm's and in reverse.
However, yesterday it started making a really loud buzzing noise when I turn my steering wheel. I have a video posted below of where the sound is coming from. Its in the belt area shown.
Has anybody else had a similar problem or know what needs to be fixed? The car has 125,000 miles on it. I'd really appreciate any input or advice. Thanks
<embed src="http://www.youtube.com/watch?v=esKLCchNXqg"></embed>
Old Oct 28, 2009 | 08:43 PM
MaDstreet's Avatar
9th Gear
it's look like you power steering pump is dead , check if the level is correct
Old Oct 28, 2009 | 09:14 PM
awinn's Avatar
I just checked and yes the power steering fluid level is quite low. i will pick up some fluid tomorrow from the dealer and see if that helps any. do you think that is the only problem or is the pump itself more likely the issue?
Old Oct 28, 2009 | 09:20 PM
silkk8482's Avatar
Check to see if it is your harmonic balancer. My just went out. I haven't got it fixed due to the fact I got in storage. I am currently deployed. I check on the price for one and it's about 65 bucks. But the labor is going to kill you so be prepared if that is the problem.
Old Oct 28, 2009 | 09:27 PM
awinn's Avatar
is that the same thing as the drive belt? I just checked my auto-tensioner arrow and it is definitely out of range according to manual.
Old Oct 30, 2009 | 06:26 AM
silkk8482's Avatar
Take it to the dealer. I thought it was my drive belt to and I had it replaced but it wasn't. I have about 94,000 miles on mine and it's and 04. THe harmonic balancer is towards the bottom. It is really hard to get to thats why it is going to cost you an arm and a leg for labor. Be prepared if thats the problem
Old Oct 30, 2009 | 11:38 AM
thunder04's Avatar
Sweet!
Sounds like a bad PS pump to me.
Old Apr 13, 2014 | 08:20 PM
JazzyJD's Avatar
P/S Pump
I looked at your video YouTube. I am having the same issue with my 06 TSX. You stated that you change your power steering pump hose. There are 2 hoses that connect to the power steering pump. Which one did you replaced?
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
iCrap
Sep 11, 2015 06:21 PM
aces2412
3G MDX (2014-2020)
Sep 7, 2015 08:40 PM
