creaking sounds from the back
Old Jan 2, 2006 | 11:07 AM
lcrazyaznl's Avatar
CL9 ABP
It like a spring is getting pulled to its max when ever my friends and I exit my car. The car is a 2005, and only 21k miles. I'm not so sure if this is a sway bar issue, becasue would the sway bar make a cracking sound if it was not lubed up time?
I did remember when i first installed it I didnot tighten it fully and it caused some sounds, but now its just crazy every bumb and leaving the car some weird cracking sound from the rear.
I'm going to bring it to the dealer, but I wanted to ask if anyone had this problem.
Its really weird cuz everyone gets out maybe only one girl it sounds like the car lost 800 lbs of weight. That kind of creaking sound.
Old Jan 2, 2006 | 05:06 PM
pizzaman555's Avatar
I have the same problem with my sway bar, it was fine when first installed but now it makes noise over just about every bump.
Old Jan 2, 2006 | 10:13 PM
lcrazyaznl's Avatar
CL9 ABP
Yea but is it a loud spring pull sound like errr errr errr when people get out?
Cuz its just getting worse and i think i should check things out.
Old Jan 2, 2006 | 10:28 PM
JTso's Avatar
Did you apply lube during the swaybar installation?
Old Jan 3, 2006 | 12:12 AM
lcrazyaznl's Avatar
CL9 ABP
Yes I did, anyone know what lube i should use?
Old Jan 3, 2006 | 12:24 AM
Sailbum's Avatar
3rd Gear
Suspension noise
Even though you lubed the bushings during install, they may need to be lubed again. Poly bushings (I think that is what Neuspeed uses) need to be re-lubed every so often, or they will squeak. I can't recommend a lube, check with Neuspeed or one of the forum sponsers.
I recently had a clunk/squeak at low speeds especially over speed bumps and entering driveways. Turns out the right rear sway bar end link was loose, an easy fix.
Good luck,
Mike
Old Jan 3, 2006 | 05:24 AM
moda_way's Avatar
Lithium grease and lots of it.
Old Jan 3, 2006 | 08:36 PM
lcrazyaznl's Avatar
CL9 ABP
Any ideas where I would find it? Now when we lube the bushings are we lubing almost every thing? When I first installed it was sort of unclear what parts to lube but the inside of the bushing.
Old Jan 3, 2006 | 11:28 PM
JK5one3's Avatar
hey, this might be it?
https://acurazine.com/forums/showthr...7&page=1&pp=25
i have the trunk problem with my tsx.
Old Jan 4, 2006 | 05:46 AM
moda_way's Avatar
Just about any auto store. I got a mini grease gun from Sears and it came with Lithium grease.
Old Jan 4, 2006 | 09:13 AM
lcrazyaznl's Avatar
CL9 ABP
Im not so sure its a trunk problem but thanks i'll check that out. Its more of the errr errr eerrr errr sound when you get out of the car...
Old Jan 4, 2006 | 11:16 AM
lcrazyaznl's Avatar
CL9 ABP
Problem was the swaybar, brought it to the mechanic, and he said it was inside the bushing was not lubed enough. He used super lube. I forgot what is in it he said but the sqeaks are all gone.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
Iain MacLeod
Sep 17, 2015 01:01 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
