Creaking noises coming from the steering column / center console
A few days after I got my car, I noticed some creaking noises coming from the steering column and/or the center console. Here's what I've determined so far:
- The noises are most prevelant when moving slowly (idle speed)
- The car does NOT have to be moving to hear the noises - if I turn the steering wheel while standing still I can hear it.
- The steering wheel does NOT have to be turning to hear the noises - going straight at a low speed, I can still hear the noises
- The noise is not coming from me moving around in the seat.
- The noise is not coming from the sunroof.
I took it into the dealer and they basically said "I don't hear anything" and then "Oh that's just the noise of the leather in the seat and the steering wheel" (Mike Harvey Acura).
Does anybody else have this problem?
Help!
Help!
yeah i have about 10 or so things causing creaks and noises. you just gotta get used to it. most of the tsx's out there have them. I reccomend getting into some good music, with the stereo on 12 or higher all of the noises pretty much drown out.
Re: Creaking noises coming from the steering column / center console
Help!
Help!
I just recently noticed the dash or center console creaking noises a few days ago -- pretty loud, but only when I accelerate or turn at low speed. I also did some tests, and found it had nothing to do with the seat or sunroof. Not sure what to do, or what can be done
Hey,
You stated that you have creaking sounds coming from the console area: Do you have the 5 speed?
If so, check to see if they are coming from your shiftgate panel. I had this problem where when I braked, and accelerated...it would creak and crack. I took it in to Acura and they took the console panel out and lind the portion that goes over the shiftgate panel with thin tape. It has since stopped. The technician told me that it was due to the plastic peices rubbing against each other.
One thing: Check the area out afterwards. In the process of repairing this... the tech scratched the shiftgate panel and also put a scratch on the top compartment door. I had them replace all panels and all is fine now.
Originally posted by brerpie
Hey,
Hey,
Good point also about inspecting afterwards. After my dealer fixed the dash rubbing rattle, I found black/greasy handprints all over the passenger side pillar (and I've got the Quartz interior!). I was able to get 'em off with soap and water, but it scared me. After my 5k oil change yesterday, I found little greasy specks near the driver door speaker area -- again I was able to get 'em off. I'm gonna mention this stuff to the dealer, the next time I get a chance.
No luck. I had two service people ride with me to listen to my creaking dash area. I'm driving through the dealer lot doing little figure 8's, and the dash is creaking away, and they're saying, "OK, let me know when you hear it." I actually said "you gotta be kidding me, just listen."
Bottom line, they said bring it in when it gets worse -- otherwise the techs will just be running in circles trying to pinpoint the cause. I suppose they're right.
I honestly didn't think the dealer would be able to help, but knowing I tried makes the creaking a little more bearable -- although still embarrassing
Thanks for the update. Maybe you should have let them drive it, it may be more noticeable in the driver's seat. I'll be taking it in in a few weeks, I'll let everybody know how it goes.
Hopefully someone else, with a slightly louder creak, or a service tech with better hearing, will have some luck.
In the meantime, I'm upping the RPMs and the volume to drown out the cabin noises.
For what it's worth, about a month or two ago, the dash began cracking/creaking for me. It was quite embarassing when I had people in the car. In any event, I messed around with the passenger side A-pillar - pushed it up & in near the windshield & door, and the creak has never returned. It's been three weeks now, and nothing - one rattle down, fifty to go.
My 05 got so many rattles that I thought I'm driving a Yugo !
http://www.inet.hr/~bpauric/eindex.htm
Vistied the dealer 6 times, no luck, they must have a hearing problem or it's just me ?
Oakes
Wash & Wax
10-12-2015 11:17 AM
