Creak sound in rear
I have an 05 TSX that has 4500 miles on it now. It has just developed a creaking sound when I pull into a driveway or onto a street that has an approach that is inclined like a ramp. It seems to do it due to the body flexing and can only be heard coming from the back seat/rear window area. Has anyone else noticed a creak sound like this?
Originally Posted by ams_chris
yeah i get it from time to time when im backing out of my driveway. Ive had the car for a month now [1200 miles] ....
aahh...
the spot weld residue from the rear cross member...
yup, i have that too. a solution i read about was to split the 2 pieces of metal, held together with the spot welds, thereby increasing the space between them and not allowing the spot weld residue to touch...
haven't done it yet, nor do i know how difficult the job may be. but, like you, i'd prefer to fix this annoyance myself...
yup, i had tat problem last month. and it took Acura 2 attempts to get it fixed. After the first "fix", the sound came back a week later but much worse. and they told me they tightend everything up the 2nd time around...but now i got steering column rattles
I had that same noise from rear too... it happened exactly like you described. I took it to my dealership and they fixed it on very 1st attempt... I was told they lubed something inside the trunk... I didn't ask for the exact detials though, but at least it seems an easy enough fix for them.
all these talks about spraying wd40... doesn't that risk rusting? I think I've heard from somewhere that wd40 could cause rust... or increase the chance of that?
wouldn't regular machine lubing oil be safer?
Originally Posted by starvin
sorry for being a noob, but do you have any pics of where you sprayed the wd-40?
im starting to get a few creaks from the rear as well.
will someone plz take a picture. someone posted a pic in another thread but it seems their trunk looks differen't. someone with an 05?
I also hear a creak when backing out of my driveway or going over like a speed bump at an angle. seems to be the back left area of the rear.
this is the link to the old thread if your interested
http://www.acura-tsx.com/forums/showthread.php?t=23667
I sprayed WD-40 on the spot welds on the rear cross member and it took care of the creak. I guess that was easy enough!
did you have to open up the trunk lining to do this, or, can this job be done with, at most, pulling down the rear seats?
so...
i just sprayed some wd-40 onto the rear cross-members. the difference is like night and day.
i still have some creaking on the drivers side, but it's very minimal. i'll just have to lash more wd-40 onto that side later.
excellent info...
excellent info...
Do you know what they did to tighten it up? Did they put more spot welds in it?
Originally Posted by afici0nad0
excellent thread...
WD-40 won't increase your chances for rust, it actually helps prevent rust!
Sorry to revive a dead thread, but the links to the pictures are now down. I have the creak..does someone have a picture of where to put the wd-40? What is the cross bar member and where are these spot welds everyone is talking about?
rockyboy
Aug 4, 2024 10:35 AM
snorf
Nov 4, 2019 06:44 AM
