Clutch Creak
Old May 21, 2008 | 11:43 AM
925tsx's Avatar
B A N N E D
Clutch Creak
Im having a problem with my clutch (i think)
when i push the clutch in, or let it out there are like 2 spots where i can feel a "creak" or a "notch" for lack of better explanation. THIS ONLY HAPPENS WHEN IT IS RAINING OUT. I dunno what the heck is going on.
Clutch pedal is perfectly fine when its not raining.
There is no noise, no performance issues, just the feeling.
Anyone?
Old May 21, 2008 | 12:38 PM
LukeaTron's Avatar
Sounds like either the master cylinder problem or the switches (ignition interlock and cruise control cutoff) are sticking a bit. There's a freaking huge thread on this issue.
Old May 21, 2008 | 01:30 PM
cmschmie's Avatar
Living the Dream
https://acurazine.com/forums/showthr...ghlight=clutch
I had the same issue. It's the master cylinder.
Old May 21, 2008 | 01:57 PM
925tsx's Avatar
B A N N E D
its the master cylinder? it only happens when it rains. if it was the MC wouldnt it happen all the time?
Old May 21, 2008 | 02:33 PM
LukeaTron's Avatar
Brake fluid is hygroscopic. It will absorb moisture if exposed to it. It's possible (granted it doesn't seem likely) that's why it's happening.
Other than the getting worse in the rain part, the symptoms you are describing are dead on for the master cylinder though.
Old May 21, 2008 | 02:38 PM
925tsx's Avatar
B A N N E D
its not that it gets worse in the rain, it only happens in the rain, period.
Old May 21, 2008 | 02:43 PM
cmschmie's Avatar
Living the Dream
Not to put you down, but I'd be willing to bet that it's "happening" all the time, you can just tell when it rains for some reason.
Basically what is happening is that as the piston is sliding in the master cylinder it's leaving deposits at one end. Well every so often the piston will get stuck on those deposits, hence the click.
It will get slightly worse over time. It's not damaging, just annoying.
I bought my car Mar '06, notice the click late that year. Early '07 I had it fixed (replaced master cylinder) and have not had any issues since.
Old May 21, 2008 | 02:47 PM
925tsx's Avatar
B A N N E D
ill keep an eye on it, im pretty sure its not happening when its not raining. but ill keep u posted.
Old May 21, 2008 | 07:30 PM
Tmak's Avatar
Not sure if this is the same problem I have.. but the only way I can describe it is it makes this noise when I'm letting go of the clutch, it doesn't happen often.
http://youtube.com/watch?v=HQbWSU1SOEw
Anyone have this same problem?
Old May 22, 2008 | 09:37 AM
daddydliv's Avatar
Faster, please.
I had my master cylinder replaced a while ago while it was still under warranty because it was clicking. Since then, no clicks but lots of creaking, but only when it's damp or humid out. When I say creak I mean like the sound of wet sneakers on a linoleum floor or a squeaky door hinge.
I deal with it by greasing the clutch every so often.
And there are tons of threads on all of the clutch noises.
Old May 22, 2008 | 09:39 AM
daddydliv's Avatar
Faster, please.
I have started hearing this same noise, too, but I'm assuming it is the clutch starting to slip a little (I have 117,000 miles on it). How many miles are you at?
Old May 22, 2008 | 06:54 PM
Tmak's Avatar
I have about 96,000 KM's on my TSX, and the clutch functions with no problems, I put it in 6th gear and put my foot down at low rpm and it doesn't slip at all. I find it depends more on how I drive it, when the clutch and gas are parallel it makes that noise.. kinda hard to explain it but I just drive it better now and it doesn't creak that much now.
I've been researching this for the past few weeks and will be bringing it to a mechanic soon and hopefully they can diagnose this. The mechanics at Acura were completely useless.
Old May 22, 2008 | 10:14 PM
LukeaTron's Avatar
That noise could be the throw out bearing.
Old May 23, 2008 | 08:28 AM
925tsx's Avatar
B A N N E D
I am not experiencing any noise at all, but i can feel it in my foot.
and it is 100% without the slightest doubt in the world only happening when it rains hard.
No clue what it is.
Old May 23, 2008 | 08:57 AM
Tmak's Avatar
The mechanic at Acura couldn't figure out what the problem was, how would I bring up this as the source of the problem? I don't think they'll just take my word for it if I go and tell them it's the throw out bearing.. I'm assuming it's under warrantee
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
