clunk in transmission
Old Jul 16, 2009 | 03:44 PM
gt489's Avatar
i recently did the axles in my 04 tsx 6sp. now on the initial release of the clutch in any gear moving or not theres a clunk noise comin from the tranny. its not the motor mounts checked those. and now theres a slight shake from 15-20 mph. could it be low on fluid?
Old Jul 17, 2009 | 05:42 AM
moda_way's Avatar
Which axles did you use? Could be a balance issue and would talk to the manufacturer of them for warranty. Are you sure you seated them correctly?
Old Jul 17, 2009 | 09:29 AM
gt489's Avatar
i used drive shaft shop axles. ive done about 4k miles since ive put them in. how do i check to see if they are seated correctly
Old Jul 23, 2009 | 02:56 AM
raya's Avatar
Same thing happen to my DSS level 0 axles after installation.
It clunks whenever I switch gears. And the vibration that initially went away with the axle change came back after a while.
I had an Acura mechanic check to see if they were properly seated and they were.
I'm going to change the Axle on the passenger side again with a different brand to see if that will fix it, since the inner joint on the DSS axle doesn't fit like the oem one.
Old Aug 11, 2009 | 02:26 PM
gt489's Avatar
please let me know the outcome of this axle change
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
Brandle34
Sep 23, 2015 07:20 PM
