Clunk noise over bumpy road.
Old Mar 26, 2007 | 04:29 AM
euroStyle's Avatar
I've had this problem for a while now.
But everytime i go over bumpy road, i get a clunking noise from the brake/wheel area. but if i apply the brakes just alittle bit, it goes away. Im at 47K and as far as i can remember, ive had it since i changed the brake pads at 35ish. and i checked it and everything seems to be on tight.
I had the dealers check it and blamed on the suspensions, tein SS.
Any ideas?
Old Mar 26, 2007 | 05:02 AM
moda_way's Avatar
I think that is the Tein SS unfortunately. Do you have an RSB? If so, you could have loose endlinks or check the endlinks anyway. There is a TSB around them.
Old Mar 26, 2007 | 06:51 AM
aaronng's Avatar
Driver/Detailer
Does your Tein SS have upper pillowball mounts? The pillowball mounts gives a clunking sound.
But it's still a different sound to the RSB clunking (which is more of a twang)
Old Mar 26, 2007 | 07:00 AM
OldManTSX's Avatar
Could be your rear sway bar. Noises went away after bushings were lubricated.
Old Mar 26, 2007 | 07:56 AM
BulldogHockey's Avatar
Ditto for me
Old Mar 26, 2007 | 08:14 AM
xizor's Avatar
Bye TSX, hello domestic?
Any ideas?
maybe a worn camber kit?
Old Mar 26, 2007 | 10:06 PM
euroStyle's Avatar
the sound is from the front of the car.
the SS does have the stock pillow mount, and that makes a slight noise, but its a different noise.
How do i check for worn camber?
but the noise is gone when i apply brakes even a little bit.
Old Mar 26, 2007 | 10:09 PM
darth62's Avatar
Not an Ashtray
Any ideas?
When you hit a bump, your lose traction for a moment. This causes the TCS/VSA to activate. So, I suspect that the sound you hear is your ABS.
Old Mar 26, 2007 | 11:08 PM
aaronng's Avatar
Driver/Detailer
ABS is not a clunking sound.
Old Mar 26, 2007 | 11:15 PM
darth62's Avatar
Not an Ashtray
I'm not sure what he means by "clunk." I definitely hear something happining that is "clunk like" everytime I hit the big bump near the ramp onto the highway. I think it is probably the ABS. But, then again, unless we want to post .wav files, I guess there is no way of knowing if we are talking about the same sound.
Old Mar 26, 2007 | 11:21 PM
aaronng's Avatar
Driver/Detailer
When my ABS engages, it is a grinding sound.
Old Mar 27, 2007 | 12:56 AM
JTso's Avatar
If you follow the Tein SS instructions and set the front strut lower spring perch to 30mm from the reference mark, this is just about the lowest adjustment point with very little preload on the spring. If the car is lowered to the ground with this setting, the top of the dust boot is very close to the washer right above it. If you drive over speed bumps, the suspension compresses and the bump stop could come in contact with the washer and makes certain thumping sound, but not clunking. You can tell very easily by the mark on the washer. If you lower the car more, the car is essentially riding on the bump stop.
Old Mar 28, 2007 | 02:02 AM
euroStyle's Avatar
I exactly know that "thumping" sound. My settings are at factory height it came with. Should i raise a little bit? or am i ok driving with that thump?
And the clunking is a different sound/issue.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
