clicking noise under the hood
Old May 6, 2005 | 01:01 PM
seinfeld44's Avatar
5th Gear
In the mornings, after turning on the car and changing gears to "drive", when I accelerate, I hear a clicking noise under the hood. It almost feels like a twig is caught beneath the hood, and is being dragged. After the car changes from 1st gear to the 2nd, everything is normal. This only happens if I turn on my car after leaving it off for a while. Is the phenomenon unusual?
Also, is it good to warm up the engine everyday before driving the car? If yes, does the engine have to be at a certain RPM before we know that the engine is sufficiently warmed up?
Thank you
-s-
Old May 6, 2005 | 01:07 PM
iamhomin's Avatar
04 remembrance
Ah-ha! It may be the same problem I faced.
Let me do a quick search to find the thread...
*edit, ~https://acurazine.com/forums/showthr...tapping+noises
Do you know where the sound was from?
Old May 6, 2005 | 03:10 PM
CarbonGrayTSX's Avatar
3rd Gear
seinfeld, this could be the ABS doing its check. I get that on mine too and when I called in to the dealer they said it's perfectly normal. In my case it only does it once, as soon as I accelarate in the morning and I usually never heard it again while driving.
Hope this helps!
Old May 9, 2005 | 09:21 AM
seinfeld44's Avatar
5th Gear
Thanks to iamhomin and carbongreytsx. I looked at the discussion you pointed me to, iamhomin. However, the symptoms seem to be different. I get this clicking noise even on a clear sunny day. I have another car with ABS, but that car doesn't have this clicking noise when I start. Could this be something else carbongreytsx?
-s-
Old May 9, 2005 | 11:10 AM
drunkenbuda's Avatar
Got Phó?
Sounds bad, clicking is bad....go to your dealer and have it check out.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
thegipper
Sep 28, 2015 01:01 PM
Bielikb96
Sep 28, 2015 10:45 AM
