Checkup before warranty expires
My warranty expires this April. I want to know if there is any check up I need to get done before it expires. What type of check up should be performed to make sure everything is alright (engine et al)?
JDM Addict
Replace engine oil.
Replace engine oil filter.
Inspect front and rear brakes.
Lubricate all hinges, locks and latches.
Rotate tires (follow pattern on page 276 of your owner's manual).
Inspect tie-rod ends, steering gearbox and boots.
Inspect suspension components.
Inspect drive shaft boots.
Replace air cleaner element.
Inspect drive belt.
Replace dust and pollen filter. (See Dust and Pollen Filter on page 270 of your owner's manual for replacement information under special driving conditions.)
Inspect drive belt.
it's a car-drive it
Before the warranty expired on my 06 I brought it to the dealer for service (it was due for a oil change and tire rotation. I asked them to check it over good before the warranty ended. They did-no problems found.
I called the Acura dealer today. They told that there is no checkup that Acura does before the warranty expiration. They told that they can correct any problems that I have.
kixo
09-25-2015 03:07 PM
