Check Engine Light with CAI
Old Apr 1, 2006 | 12:02 AM
stewie20068's Avatar
So for the past month or so I occasionally hear a whistling noise when my revs are about 2500. I didn't have the whistle before I got my injen CAI so I assume its from that, but I've tried tightening all the hoses and clamps so I'm not sure what's wrong.
then pollen season just hit georgia and my "Maint. Req'd" light just came on. I took it to the dealership and they said I would have to leave the car with them to check it out.
In what way could my intake be causing this problem and what can I do to fix it?
Old Apr 1, 2006 | 01:53 AM
Tsx536's Avatar
Rep'n Taxbrain.com
Go to Autzone, borrow an ODBII scan tool, and read the code it throws.
You have the IAT sensor hooked up properly? It plugs into the rubber elbow.
Old Apr 1, 2006 | 02:19 AM
JTso's Avatar
So, is it check engine light or maint req'd lights? They are not the same.
Old Apr 1, 2006 | 11:49 AM
yeah sorry it's the maintenance required light. I've got the sensor in right. how much would that scanning tool cost and how difficult is it to hook up?
Old Apr 1, 2006 | 02:11 PM
xizor's Avatar
Bye TSX, hello domestic?
are you at 9000 miles?
Old Apr 2, 2006 | 04:48 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Well you orignially said it was the check engine light. That is why I said you would need the scan tool. If it's the maintenance required light that it is no big deal. No error code has been thrown It is just reminding you to do the regular maintenance. The manual will tell you how to reset it yourself.
Old Apr 2, 2006 | 05:21 PM
tony4311's Avatar
I am Ahab!
The whistle is the intake itself there's nothing wrong. If you have the dealership look into it and that's all they find (and it will be) they're most likely going to charge you for looking into it.
Old Apr 2, 2006 | 07:20 PM
So the whistle is not the usual sucking sound. It actually sounds like a leak.
The dealer tried to reset my maintenance required light but it wouldn't turn off.
Old Apr 2, 2006 | 08:27 PM
TSX420J's Avatar
CarbonGreyPearlEbony
Its stuff like this that makes me pussy out of doing engine mods. hope everything
gets resolved with no charges.
Old May 21, 2006 | 01:25 AM
Yes! I finally got my "Maint. Req'd" light to go off! I finally changed my A/C pollen filter and the light went off. who knew it could be so easy.
Old May 21, 2006 | 02:00 AM
San-AnT's Avatar
The Power of a Grill
the maint. light is to remind you to get your engine oil changed and your scheduled service $$ forked over. unrelated to your CAI in most cases. I don't think the AC pollen filter has any sort of electronic monitor. i changed mine for the 1st time at 40k. no light.
Old May 21, 2006 | 07:24 AM
I didn't think the filter would have a sensor either, however the dealer couldn't get my light to go off on multiple attempts. Then I changed my pollen filter and the light went off. Pollen filter is the only thing I can figure.
Old May 21, 2006 | 12:59 PM
waTSX's Avatar
Have camera, will travel
I don't know why they wouldn't be able to reset the Maintenance Req'd light. It's straightforward and the procedure is in the manual. The light is only a reminder, not an indicator of problems. Stealerships don't know shit about the very cars they sell.
Old May 21, 2006 | 09:13 PM
I thought it was just the dealer service people being retarded, but I couldn't get it to go out either. I looked it up the manual to see how to do it and it didn't work. So I finally gave up and just resigned myself to having the light on all the time. But then I changed my filter and it went out. so good stuff.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
