Center Armrest Loose
Old Aug 11, 2007 | 10:38 AM
jswim99's Avatar
I just noticed today when cleaning my 06 that the center armrest has quite a bit of lateral play in it. It's very noticeable from the back seat; I can grab it and wiggle it side to side quite a bit. Is this just "the way it is" or did my armrest somehow loosen up? Is there an easy way to tighten it?
I'm thinking this could have happened when the dealer adjusted my parking brake at the last service (is the adjustment even made at the brake handle?).
Old Aug 13, 2007 | 10:30 PM
jswim99's Avatar
Nobody knows?
Old Aug 13, 2007 | 11:31 PM
clee109's Avatar
I Quit
lift up the rubber cover on the bottom of the console (the aux/power compartment) and you'll see these two screws:
they are phillips head screws, tighten them down. Those are the ones that hold the back of the center console down.
Old Aug 14, 2007 | 12:20 PM
LoveMyTL-S's Avatar
Did that fix the problem?
Old Aug 14, 2007 | 02:10 PM
jswim99's Avatar
I'm gonna try it tonight when I get home. Thanks for the suggestion!
Old Aug 14, 2007 | 04:09 PM
steeveage's Avatar
Tormented by mod choices
While you're messing around with those two screws you may as well take off the entire center armrest and install a short shifter
Old Aug 15, 2007 | 06:21 AM
jswim99's Avatar
So the two screws were loose. Not sure how that happened... Tightening them fixed the problem, thanks!
Old Aug 15, 2007 | 06:45 AM
LoveMyTL-S's Avatar
Good to know, thanks for the feedback. Glad it fixed your problem............
ITSJESTER
17
Dec 6, 2018 02:29 AM
vpasla1
Sep 17, 2016 07:24 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
ROWDY621
Sep 30, 2015 03:20 PM
