CEL on now...what to check for?
Old Aug 1, 2008 | 04:54 AM
DiaBando's Avatar
gistered User
With a Hondata reflash, K&N Typhoon, CT-header, RT cat, and Tanabe SMT installed. What could be the problem causing the CEL light to remain on?
Old Aug 1, 2008 | 05:05 AM
aaronng's Avatar
Driver/Detailer
Use an OBDII code reader to read the code.
Old Aug 1, 2008 | 07:27 AM
DiaBando's Avatar
gistered User
Thanks, aaronng. Is there one than works best with an acura? Innova makes one for @ $60 (us)
Old Aug 1, 2008 | 10:10 AM
PACman's Avatar
Any OBDII scan tool should do the job. Typically you can barrow one at the local chain auto parts stores. Then post the code up here or search the web to see what it means.
Old Aug 1, 2008 | 03:35 PM
1TSXer's Avatar
Resident Metal Head
Most likely it's due to the RT Cat. I should be getting mine in about a week and I'm going to install a CEL elliminator on mine just to be safe.
Old Aug 1, 2008 | 06:19 PM
vthree's Avatar
2006 ASM tsx
hmm u can drive by any autozone and borrow theirs.. usually i scan..
i've had one cel that will come on every few months..
i reset it and it doesnt come on for a while.......
Old Aug 1, 2008 | 07:37 PM
JTso's Avatar
My guess would be the cat.
Old Aug 1, 2008 | 08:15 PM
DiaBando's Avatar
gistered User
I don't think I've seen an autozone in my area. I'll check. pep bros, strauss, sears.
Old Aug 2, 2008 | 07:07 AM
moda_way's Avatar
A simple anti-fouler will fix the issue if it is the cat. I'm running one now.
Old Aug 5, 2008 | 05:49 PM
DiaBando's Avatar
gistered User
I removed the CEL by disconnecting the neg battery terminal. After which I purchased a nice Innova 1003 CEL tool. Connecting found no stored DTCs, and the TSX feels really full of piss n' vinegar since clearing the light; meaning I'll wait until the next CEL light to come on, and worry about it then. Bethany Beach, here I come.
Old Aug 6, 2008 | 09:17 AM
jlukja's Avatar
^^ Did you use the code reader first or did you remove the CEL first? In either case, if its a persistant problem then the CEL should reappear. Read the code first before clearing it otherwise you won't know where to start your troubleshooting.
Old Aug 6, 2008 | 09:33 AM
LuvMyTSX's Avatar
Just in case you need one, there's one on Rt. 22 near Whitehouse and another one just south of the Somerville Circle on Rt. 206.
Old Aug 6, 2008 | 09:40 AM
DiaBando's Avatar
gistered User
Right, jlukja. I used the code reader first. The 'EV' test, on the code reader didn't complete after nearly 10 minutes of connection (amber light on code reader display). I then disconnected the neg terminal for 10 minutes, or so. The CEL light, of course, disappeared. I retested, and no DTCs came up, or were stored in memory (green light on display). And I would assume the CEL will pop-up again for me to test.
Old Aug 6, 2008 | 09:54 AM
DiaBando's Avatar
gistered User
Thanks, LMTSX. There is one in plainfield, pretty close. I ended-up buying a code-reader at Sears. Autozone, on the phone, had no idea what a 'defouler' was, when I asked.
Old Aug 6, 2008 | 12:04 PM
Tsx536's Avatar
Rep'n Taxbrain.com
^^ It's also called an anti-fouler
Old Aug 6, 2008 | 12:14 PM
moda_way's Avatar
And you'll need to drill it out a little with a 1/2" drill bit to accomodate the O2 sensor's tip.
Mike Pilipenko
Mar 26, 2024 09:21 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
hrothgar02
Sep 28, 2015 11:08 AM
