Car is starting to no shift from Park position. What's going on?
Old Sep 14, 2011 | 11:16 AM
surferdude949's Avatar
8th Gear
2004 TSX auto 120k
My car is starting to not shift from the Park position to drive (shifting left to right).
It works some times and at times I have to try several times before the shifter moves to the right.
What can be causing this?
Old Sep 14, 2011 | 11:58 AM
8th Gear
Forgot to mention the "VSA" light is on and won't turn off.
Old Sep 14, 2011 | 12:04 PM
DaChef320's Avatar
Registered Member
it means time for a new car
Old Sep 15, 2011 | 03:13 PM
invalidalias's Avatar
does it shift out of park when you remove the little shift plate tab and stick a screwdriver down in there? Also If you listen real close, maybe just with the key in the on position and the engine not running, hit the brakes and see if you can hear the little plunger solenoid click. When you hit the brakes it should activate which will allow you to move the shifter around. If you hear this then the sytem is working properly and you'll need a new shifter assembly mechanism. good luck
TL-Rocket
Apr 29, 2023 02:33 AM
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
kuzdu
Sep 10, 2015 08:42 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
