Camber problem!!!!!
Old Aug 19, 2004 | 12:57 AM
warmboi504's Avatar
8th Gear
Camber problem!!!!!
Well my mom took my car and I don't know what she hit but it made my rear right camber all screwed up. Can I take it to factory and get it fixed or will I have to get a camber kit for them to fix it?
Old Aug 19, 2004 | 03:07 AM
sauceman's Avatar
Moderator Alumnus
Take it back to your dealership, they'll repair it. Only, they might have to replace some suspension parts and it might not be done on warranty.
Old Aug 19, 2004 | 05:32 AM
DarkLava's Avatar
I hope whatever she hit was a stationary object. If not, and it was crawling around, it isn't crawling around anymore! It'd take a pretty good hit to screw up the suspension links or the hub...
Old Aug 19, 2004 | 01:47 PM
warmboi504's Avatar
8th Gear
Well, I took off the wheel and inspected the suspension and I don't see a thing wrong with it. No damage to the parts. It must have shifted one of the bars a little when it was hit. Do you think I could fix it by taking it apart and putting all the links back together?
Old Aug 19, 2004 | 02:03 PM
xizor's Avatar
Bye TSX, hello domestic?
If nothing is broken, logically one would think anything that can be done, can be undone. I believe there's a certain amount of play in the rear, have your dealership check it out.
Old Aug 19, 2004 | 02:11 PM
ClutchPerformer's Avatar
Originally Posted by warmboi504
....Do you think I could fix it by taking it apart and putting all the links back together?
Not if something is bent. Take it to the dealer. And make your mom pay for it.
Old Aug 19, 2004 | 02:56 PM
Brooks's Avatar
My dealer told me that they will waranty my alignment up to 12k miles. Of course I put on springs now so I will have to pay to have it done. Take it in to the dealer and have them do a 4 wheel alignment. Make sure you get a print out before and after the alignment.
Old Aug 19, 2004 | 06:04 PM
warmboi504's Avatar
8th Gear
I called Acura and they said they can't fix camber. I check over and over again and nothing seems bent at all. I just think it just shifted the angle of one of the links. Well me and my friend are gonna work on it and hopefully we get it strate if not I'll just buy a camber kit i guess. Thanks for the input.
Old Aug 19, 2004 | 07:21 PM
There's no camber adjust on the stock suspension links. That's why we have to buy camber kits when we lower the car. If your camber has changed drastically without an aftermarket camber adjust, then something is bent. A camber kit will not help you. Take it to the dealer.
Old Aug 19, 2004 | 09:16 PM
Dan Martin's Avatar
Photography Nerd
You definitely don't want to buy a camber kit to correct for collision damage. That's just masking the problem not fixing it.
Old Aug 21, 2004 | 09:11 PM
warmboi504's Avatar
8th Gear
My friend and I looked at it again and couldn't see anything bent or damaged, but when you take a look at the wheel it looks so awkward. The more I look at it I cant' really tell if its camber or toe or both. I will take it to the dealer to take a look at this week. Oh yeah, another thing, When I drive I can hear a noise coming from the right rear but its not the tire and it is a very constant sound. The faster you drive the louder it is. I can't see anything rubbing. Any other ideas about whats wrong other than suspension links cause I checked and its not the suspension links as far as I can tell.
Old Aug 21, 2004 | 11:13 PM
Dan Martin's Avatar
Photography Nerd
You probably also need a new wheel bearing. That could very well be the cause of the sound.
Old Aug 21, 2004 | 11:53 PM
You won't be able to see bends that cause single digit degree changes in camber. Take it to the DEALER!
Old Aug 25, 2004 | 11:20 AM
tsxhondatuner's Avatar
6 speed yo!
thats why my parents arent allowed to drive my car
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
lanechanger
Oct 13, 2015 10:56 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
0opie
Sep 22, 2015 04:15 PM
