A/C Condensation Drain Location
Old Jun 26, 2008 | 06:30 PM
LukeaTron's Avatar
So for a while I've been hearing what sounds like water sloshing around when go around bends and what not. Well with the increase in humidity around here this week it's gotten much more prevalent. Then every time I turned left I would get the sloshing followed by a sizzling sound. I had my suspicions about what was causing it and I just confirmed it.
I pulled the blower out from under the passenger side dash and the bottom of the plenum is full of water. It seems the condensation is not draining out. When I would make a left turn the water would slosh over to that side and the spinning blower would sling it all over the place.
So now the question I have is where is the drain located? I couldn't readily locate any sort of tube or the low point of the ductwork. I wasn't about to start pulling the dash apart for an exploratory mission. If it's easy enough to get at I'll just clear it out myself but if it's a big a pain this has warranty work written all over it.
Old Jun 27, 2008 | 07:54 AM
LukeaTron's Avatar
Anyone?
Old Jun 27, 2008 | 08:30 AM
moda_way's Avatar
Post #6
https://acurazine.com/forums/showthread.php?t=33687
Searched by water drain leak
Biggie_B
May 27, 2025 05:51 PM
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
hashbrown
Sep 29, 2015 12:13 PM
malvothegreat
2G CL Problems & Fixes
Sep 29, 2015 08:00 AM
