A/c
Old Feb 28, 2007 | 05:24 PM
jdogg022's Avatar
A/c
This is porbably a really stupid question, but how do I get the a/c on full auto?
Old Feb 28, 2007 | 05:28 PM
PWPTSX's Avatar
just press either the auto button, or the circulation button, and set the temp cold enough. that's it.
Old Feb 28, 2007 | 05:33 PM
jdogg022's Avatar
Thats what I though, still not working. hmmm
Old Feb 28, 2007 | 05:39 PM
jlukja's Avatar
Give us a little more info on what is "still not working" and what year and whether its Navi or Non-Navi.
Old Feb 28, 2007 | 05:49 PM
jdogg022's Avatar
Sorry 06 non-navi when I press the auto button, the auto light on the drivers’ side comes on, but not the passengers neither does full light.
Old Feb 28, 2007 | 05:57 PM
jlukja's Avatar
I don't believe there is an auto button on the passenger side. The passenger side light goes on when the "dual" function is engaged (i.e. the passenger selects a different temperature setting than the driver). Sorry, I'm going from memory and I have an 04, Non-Navi. Someone correct me if I'm wrong.
Old Feb 28, 2007 | 06:01 PM
mypoorTSX's Avatar
beware of perverts
My AC is always on dual, I just press auto and it comes on full blast. I have 06 non-navi.
Old Feb 28, 2007 | 06:05 PM
PJS's Avatar
PJS
Full is not split, it's the same on both sides of the cabin and driver temperature dictates overall temperature, IIRC.
Old Feb 28, 2007 | 06:57 PM
jdogg022's Avatar
Here is a pic of what I am taking about
Old Feb 28, 2007 | 07:39 PM
crazybaboon6000's Avatar
Mugen freak
thats normal, the dual climate control only applies for the temperature of the air. The actual air velocity is controlled only by the driver, even during dual mode. What you are seeing is completely normal, it should only say auto on the drivers side climate control.
Old Mar 1, 2007 | 09:04 AM
jlukja's Avatar
BTW, thanks for the pic jdogg, it was worth a 1000 words.
Old Mar 1, 2007 | 04:24 PM
jdogg022's Avatar
Whats the point of the lights if they never turn on?
Old Mar 1, 2007 | 05:01 PM
jwhite4's Avatar
Semi-related question - if in either full 'Auto' or Auto but non-AC mode, is there any way to have the fan speed, which ventilation mode, etc. is operating? So far the only way I've found to see them is to go into Manual mode, which sort of defeats the purpose. I've had other cars with digital automatic climate that still allow you to see what exactly it's doing.
Jeff
Old Mar 1, 2007 | 05:29 PM
PJS's Avatar
PJS
Possibly a feature that was never implemented by Honda.
A generic OEM LED module which Honda's AC setup had no need for the other Auto lumination.
That or it switches to the unused on on right hand drive cars, so Auto is always lit on the driver's side of the cabin.
Who knows?
Old Mar 1, 2007 | 06:21 PM
jlukja's Avatar
Jeff
The A/C system works like this. If you put it on "Auto" it will control everything. Once you make some other adjustment it will control everything except for the item you adjusted. So, for instance, if you go to "Auto" and then hit the "A/C" button it will turn off the A/C but continue to adjust the fan speed, select recirc/fresh, and select the vents automatically. The "Auto" indicator will turn off but everything that you didn't set manually will still be automatically controlled.
Old Mar 1, 2007 | 07:35 PM
jdogg022's Avatar
Who knows?
SOunds good to me, I guess I never noticed this on the 01 or 03 TL I owned, come to think of it the 01 TL did display full auto. O well, just thought it was interesting. Thanks for the input.
Biggie_B
May 27, 2025 05:51 PM
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
hashbrown
Sep 29, 2015 12:13 PM
lovic87
Sep 15, 2015 06:07 PM
dlknight
Sep 3, 2015 07:54 PM
