brake trouble
Old Aug 2, 2009 | 09:48 PM
super4's Avatar
brake trouble
i noticed when im braking the car stops just fine but at the very end, just before the car comes to a stop it makes a wierd noise, like a little jerking, sort of like when ABS is activated even tho its defenatly not, and i feel it in the pedal, its like they slip at the end. got plenty of pads left about 8mm. thanx.
Old Aug 3, 2009 | 10:29 AM
super4's Avatar
i noticed the rotors have some groves around them, not very flat and smooth. strange that the hawk hps pads have worn so unevenly and quickly, they are like half gone in 7k, the oem ones were half at like 16k!
Old Aug 3, 2009 | 11:12 AM
thunder04's Avatar
Sweet!
Interesting. So many others have had good luck with these pads. I just ordered both front and rear sets myself. Hopefully your case is a rare case.
Old Aug 3, 2009 | 01:18 PM
super4's Avatar
ye ive heard good things about them too. they do stop a little better than oem, but they wear super fast, and i dont even drive hard.
Old Aug 3, 2009 | 07:17 PM
IDOSEO's Avatar
You must be catching the down side of a slope or slippery part of the road where they have just sealed. Mine does this in one spot everytime, its your abs or traction control turning on for a split second. Unless it happens every time then i wouldn't worry about it.
Old Aug 3, 2009 | 07:45 PM
nbtx's Avatar
still plays with cars
It sounds like those Hawk pads are chattering - whenever you deviate from stock pads, some other issues are bound to happen. If you are just using the vehicle for street driving, you should use OEM or equivalent pads.
Old Aug 4, 2009 | 12:19 AM
Itchytoe's Avatar
Modding newbie
Did you change your pads and rotors, or just your pads? If you just changed your pads, you probably have a build up of the old pad material in some section of one of your rotors that is slipping when your new pads get to that area of the pad. It's so fast when you're moving fast that you wouldn't notice it, but would notice it when you get to slower speeds because it would be more pronounced.
Old Aug 4, 2009 | 03:59 PM
super4's Avatar
well i didnt change the rotors, i figure it could have been an issue at first but thge rotors were super smooth then, and not now like 8 k later, wierd, oh well its not that bad.
08KBP_VA
Oct 22, 2019 01:55 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
