Is this a Brake Rotor problem?
Old Sep 15, 2005 | 05:52 AM
Hadoken's Avatar
When I press on the brake pedal, the car seems to vibrate a little bit.
Do I need to replace my rotors? If so.. what brand is recommended? Thanks!
Old Sep 15, 2005 | 05:57 AM
moda_way's Avatar
Have the discs resurfaced... not turned, but resurfaced. Usually involves having an abrasive discs taken over the surface of the rotors. We've found that the brake pads may be leaving deposits.
If that doesn't do it, then look into have the discs replaced.
If you do a search on brakes, you should find plenty of debate on this. I replaced my rotors, brake pads and stainless steel lines b/c I wanted more aggressive braking.
Old Sep 15, 2005 | 06:57 AM
Matell's Avatar
Matell
I too experienced this problem, and after a while there was a visible and tactile ring of brake material around the centre of the rotor surface.
I know many will advise against this but I simply replaced my OEM pads (3/4+ of material left) with some marginally better pads to abuse on the track.
In the short period that it took me to bed the new pads in (local street driving), I found that the new pads had removed the old pad material and smoothed the rotor surface to a nice shine, best of all the shudder/vibration was completely gone, and braking was good again.
Old Sep 15, 2005 | 10:49 AM
jlukja's Avatar
How many miles do you have on your car? This has been reported/discussed a number of times. Brakes are a "wear and tear" items but Acura will take care of it under warranty if you don't have a lot of miles on your TSX.
Old Sep 15, 2005 | 10:53 AM
dom's Avatar
dom
Moda, how are you liking those brembo blanks? I'm close to upgraded and may go in that direction as well.
Old Sep 15, 2005 | 12:13 PM
moda_way's Avatar
Just SLAMMED THEM HARD about 20 mins ago with a buddy in the car... they're awesome especially with the ceramic matrix pads. Now I just need my RSB to show up. I'm seriously considering putting the same pads on the rear now. They are more dirty than the OEMs, but they brake SO NICE and don't fad at all.
Raced the same guy through some country roads in his Teg GSR and he had terrible brake fad, me... I didn't even think about it.
Old Sep 15, 2005 | 12:48 PM
AChangeOfSeasons's Avatar
Matell,
What brand/type of pads did you put on?
Old Sep 15, 2005 | 12:58 PM
dom's Avatar
dom
How many miles on them so far?
Old Sep 15, 2005 | 02:17 PM
euroStyle's Avatar
I heard someone taking a soft or high(number) sand paper and it removes brake pad debris.
also, my dealer told me that if the pads are worn down past 50% than then wont cover under warrenty.
another dealer would cover it.
so it really depends on the dealer.
Old Sep 15, 2005 | 02:40 PM
moda_way's Avatar
About 6k miles. I'm rotating the ES100s every oil change, so I haven't looked at the pads and discs in 2k miles. Everything is still looking good and braking is awesome.
HOWELLiNC
Sep 10, 2015 01:39 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
asahrts
Sep 4, 2015 05:55 PM
