Belly pan or am I crazy
2005 5AT
For the past week I have heard a slighty banging under the transmission. I finally got around to looking under the car. A curved piece of plastic holding wires coming from the CC (exhaust at least), was hanging down. I snapped it back into place.
When I bought the car I thought I looked under neath it and that it had a belly pan. I may just be really confused and liked that feature on the Audis also at the dealer. Did this car come stock with belly lining and shielding under the engine? If so does anyone have pictures?
I have taken the car to the place where I bought it a few times and they put it up on the lift, apparently when they were fixing my rear window motor some idiot unplugged my passenger door lock actuator, who I was informed no longer works there. Could said idiot have also removed the shielding under the car?
El Cunado
I can't think of anything that holds wires near the catalytic converter. It sounds like you're talking about the plastic shield that is mounted under our engine. It has a removable flap to get to the oil drain plug.
Personally, I removed mine because it was annoying to deal with.
Let me help you!
http://www.acuraoemparts.com/delray/...All&vinsrch=no
It serves to protect your engine from scrapes, water, debris. It also helps with your wind drag co-efficient. The TSX has a pretty low drag co-efficient...it's even lower than that of the Acura NSX.
I don't think any of us have pictures of the shield since there's nothing interesting there. If you do your own oil changes, you have to stick your hand in an opening of the shield to get to the drain bolt. You can always lie down on the ground, reach underneath, and feel for the bolt (after you make sure your car won't roll on you). The drain bolt on the passenger side, and is probably in line with the rear-most edge of the rotor.
There have been cases where the shield has been ripped off, though (especially since a lot of us have lowered cars). I sometimes drive over debris that I'm surprised didn't damage my car, but I bet my shield took a beating for it. (I have noticed that my shield is starting to droop a little.) Thus, it could be missing due to "natural" causes.
The person who worked on your window motor probably needed to disconnect the actuator momentarily, and forgot to re-attach it.
If I ever replace the shield, I'll probably keep the flap on it though (since a new shield will come with one). I don't know if my drooping shield is also drooping due to an effect by the slight drag caused by the missing flap.
El Cunado
My dealer removed mine (I took it to them for the very first oil change). I didn't know until it was time for me to do another oil change. I think the flap hardly makes a difference since it's on the trailing edge of the shield. With it gone, I guess I save a couple of minutes on oil changes.
Let me help you!
I think not having the shield would make working on the engine a lot easier. I know it does have to be removed for certain procedures. The shield is the reason I use to not go underneath the car...lol
I agree that the pan is a pain in the neck, but there's so much crap on the roads here in the Northeast (hello.... we have winter here) that there's no way I'd leave it off. I can't imagine how dirty and salty the engine and underhood area would be (it's bad enough even with it).
El Cunado
Ah, gotcha. It wasn't really meant for security. As seen at https://acurazine.com/forums/showthread.php?t=677420 , Acura designed the TSX to be as aerodynamic as possible. I think splash protection is just a bonus.
That is the part that was hanging down. I just clipped it back onto one post. Is there another attachement point or jsut the one?
As far as the cover below the engine, where is the cheapest source for it, or the part number?
El Cunado
Call some auto scrap yards for TSX's. It's probably a part that wouldn't get damaged.
I am trying to track down the engine cover right now, memorial day seems a good day to install. Does anyone know if I can get one form any TSX 2004 - 2008?
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
